Please Help Me Figure Out This Lightbulb! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 11:05 PM   #1
Question
Please help me figure out this lightbulb!
Hello everyone,
I have reached my wits end in trying to figure out this lightbulb. I have been to Home Depot, Lowe's and a specialty light store, with no luck. Here are a few pictures of the bulb www.eleazar.org/lightbulb (including High-Res versions). I also included a few pictures of the socket, they are under cabinet lights and the bulbs haven't been replaced in the five years we have lived here, only about 4 out of 11 are still working. The light bulbs we have tried so far have been too narrow, too wide and too long (and I think too short as well). The lightbulb says 120V35W, but those are the only markings. Please help!
Thanks!
eleazar is offline   Reply With Quote
Old 05-03-2009, 11:13 PM   #2
" Euro " electrician
frenchelectrican's Avatar
looks like it is a T4 bulb shape but next time when you put up a photo of that one grab a coin like quarter or dime for referering to the size then we can able dail down to the more correct size.
Merci,Marc
{ note here unless i did read it wrong it possiblty it is a 24 volt bulb due the prints teaseing my eyes }
Old 05-03-2009, 11:32 PM   #3
Thank you for the quick reply I have attached a new picture with a dime in it. Great idea! The 1 in 120V turned white (I assume from the heat), but it is there.
Old 05-04-2009, 06:59 AM   #4
MY answer is pull the light fitting down to look for a model number and a serial number and a manufacturer and contact them.
jbradshaw is offline   Reply With Quote
Old 05-04-2009, 07:26 AM   #5
Try a 35W G8 base. Lowes and Depot should both have them.
http://doitbest.com/Incandescent+lig...sku-506834.dib
http://www.cbconcept.com/jcd-6pcsg82...ghtbulb-1.aspx
jerryh3 is offline   Reply With Quote
Old 05-04-2009, 07:29 AM   #6
Rewards Points: 2,350
Strange. I buy these at Home Desperate all the time.
Old 05-04-2009, 07:31 AM   #7
the Musigician
DangerMouse's Avatar
looks to be a halogen type bulb to me. you may have better luck going to your friendly neighborhood hardware store rather than a bigbox.
i've looked everywhere for certain bulbs, not found them.... but Stan had them!!! (should've gone there first...)
DM
Old 05-04-2009, 08:54 AM   #8
Rewards Points: 1,016
If you have a lamps plus nearby, you might give them a try. They usually carry a wide selection of light bulbs.
Old 05-04-2009, 11:04 AM   #9
Watch out that the diameter of the pins of your replacement bulb is the same as the orig.
Old 05-04-2009, 01:21 PM   #10
Rewards Points: 160
Never would have thought I would have seen that in a residence. It looks like an indicator lamp for a control panel. OP, what type of fixture does this lamp go into. I'm curious.
Old 05-04-2009, 02:31 PM   #11
Rewards Points: 156
either
It's either a t-3 or t-4 bi-pin halogen. There are different voltages. Sometimes the fixtures have a step-down transformer that will shed some more light on what type of bulb you need.
jayp is offline   Reply With Quote
Old 05-04-2009, 04:55 PM   #12
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Yes this it and if you go to the Home Depot, look where the landscape lighting bulbs are, not where all the other bulbs are.
wirenut1110 is offline   Reply With Quote
Old 05-04-2009, 06:50 PM   #13
Maybe this is not the right bulb for your application, and that's why the others burned out.
Old 05-04-2009, 07:50 PM   #14
Household Handyman
Rewards Points: 1,408
Recently bought two (2) of those: G8 bulbs, 35 watts, at Lowes (I'm sure HD has them also) in the specialty lighting section. About $4.50 each. Mine went in those under-the-counter lights you just touch a pad to turn OFF/ON.
How to figure out if room is square - install Mohawk engineered flooring shoulda hired out Flooring 7 11-08-2008 07:31 PM
Gimme a book, I'll figure it out soccio97 Introductions 1 09-03-2008 08:15 PM
How does a person figure a bid for sheetrock finish and painting? michell Painting 3 08-11-2008 04:23 PM
Trying to figure out if my used hvac is 3 ton? sheripoms HVAC 4 02-16-2008 07:32 PM
figure out electric costs frankieb9 Electrical 1 02-20-2006 09:57 PM
