Please Help, Have No Clue What's Going On. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 12:50 AM   #16
I own it now, grandmother passed away and left it to me. That's why i'm trying to get it done for myself. I have an automotive background, so I'm usually pretty good at figuring things out. Electric just scares me and i'm not exactly sure how everything works in the panel. Which is why i'm not sure what to test, or what readings to expect.
JamesB2136 is offline   Reply With Quote
Old 06-13-2011, 01:25 AM   #17
Rewards Points: 512
If you haven't done so already, take the cover off the panel. Be VERY CAREFUL inside this panel. Check to make sure that all the white wires in the panel are inserted and tightened down properly on the neutral bus bar.
If you can, a closeup pic would be great.
Old 06-13-2011, 07:48 AM   #18
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
This is one of those time when you need more help then we can give on the net.
You can't afford not to have an electricain come out and look at this problem.
Replacing a computer and tv will cost more than the electrician.
Old 06-13-2011, 08:15 AM   #19
I ask the impossible!
Rewards Points: 640
Perhaps you have teachers or students taking trade related classes that might be able to help out?
That aside, how about starting with identifying the panel - brand, model, type of breakers, ampacity of the main breaker, whatever info you can provide so we can better understand what you have. And how old is the house?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-13-2011, 08:39 AM   #20
joed's Avatar
Rewards Points: 11,992
Did the POCO open the meter and check the connection inside. IF not then they should have. Even the electricain isn't supposed to go into the meter. It also wouldn't be the first time the POCO misssed the problem on the first look.
If the problem isn't in the meter then most likely the problem is at the main breaker. Either one of the line to the breaker is bad or the breaker connection to the buss bar is bad.
Old 06-13-2011, 04:05 PM   #21
Okay, came home and tested power coming into the main. One line (multimeter on top bolt and ground) was 120. Second line (Bottom bolt + ground) was 0. I also did a lug to lug test which was 120. Apparently the problem is from the lines coming into the house. Turned off the main, pulled the meter. Both hots inside the meter box are 120. It appears the bottom female connector (for the meter itself) is slightly damaged and was split apart, causing it to arc and eventually burn out I suppose.
Being told by a friend, who's not really an electrician but has done a ton in the past while building houses that the meter box should be replaced and recheck. I tried to bend the female pin back to it's original state but I can't get it perfectly straight and i'm scared to put needle nose pliars in due to possible arcing into the hot....better safe than dead!
Anyway, does that sound reasonable for the tests I did? Should I run anymore? Or just go ahead and have the meter box replaced, recheck, and go from there?
Uploaded with ImageShack.us
Picture isn't posting right
http://img846.imageshack.us/img846/5...1320110011.jpg
Old 06-13-2011, 04:30 PM   #22
I=E/R
a7ecorsair's Avatar
I'm not going to comment on pulling the meter but since it is out, that neutral wire doesn't look good either....
What did the meter pins look like?
a7ecorsair is offline   Reply With Quote
Old 06-13-2011, 04:33 PM   #23
The bottom right pin, the one that goes in the open slot was slightly burnt at the base. The pin itself didn't seem lose, flimsy, or damaged. Just the plstice at the base. the neutral wire seemed okay and zapped me when I touched it directly instead of the bolt like a retard
Old 06-13-2011, 04:45 PM   #24
jbfan's Avatar
Rewards Points: 224
Since the meter belongs to the poco, they might have to have a say in the repair.
No way are you going to get the jaws tight enough to hold the meter, and restore and keep the lost leg working.
You need a new meter base.
The Following User Says Thank You to jbfan For This Useful Post:
JamesB2136 (06-13-2011)
Old 06-13-2011, 04:48 PM   #25
thanks man, you're about the third person to tell me to replace the meter box(base). So I feel confident that what needs to be done. I don't plan on doing that myself, don't worry. Not really interested in touching the pure live lines. I feel good about myself, being able to check and eliminate some stuff and find the problem, with help of course. Thanks again everyone for the help
Old 06-13-2011, 08:01 PM   #26
joed's Avatar
In some place the POCO supplies the meter base.
Replacement Windows? Asbestos Shingles? I have NO CLUE! Evil Scotsman Carpentry 2 10-19-2010 01:01 PM
No clue - Do I need to plaster these areas? Pedro Monteiro Painting 0 09-11-2010 07:34 PM
I have no clue what to do, NEED HELP fcarswell Plumbing 7 04-05-2010 09:00 PM
Mold in Furnace?! No clue if rental company will help with cleaning charges! Sad Renter HVAC 13 01-05-2010 02:10 PM
painting basement...no clue what I'm doing! mark415 Interior Decorating 2 02-28-2008 03:50 PM
