Please Check Out This Wiring Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 03:57 AM   #1
Lightbulb
please check out this wiring diagram
So I bought a new broan bathroom fan/lamp. Its replacing the same style unit, but this ones about 20 years newer and the wiring has changed. The original had 3 switches controlling the fan, and each lamp separately. I want to keep it this way, but the wiring running up in the ceiling to the fan doesn't have enough wires for the new units diagram. The old unit had two cables running to it. One 12/2 and one 12/3. From the new wiring diagram it looks like it now calls for two 12/3 cables. Not sure what changed? The new fan does the same as the old and looks exactly the same. Can someone check out this diagram and see if I can run all three functions separately with my old 12/2 and 12/3 cables. Also, can someone tell me what this yellow wire does, since it wasn't in the old fan. What's that symbol on the end of the yellow wire?
Thanks!
joregon3597 is offline   Reply With Quote
Old 07-07-2013, 06:51 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
The symbol on the end of the yellow wire is a thermal switch.
That's why it says that the fan may cycle when the light is on.
It needs to be fed a constant hot. This way the switch can operate it or if it gets to temperature the fan will automatically cut on.
wirenut1110 is offline   Reply With Quote
Old 07-07-2013, 12:57 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Use only 1 of the whites to supply the neutral to the unit. Remark the other as hot and use it to supply power to the fan yellow lead. This is a minor code violation.
Or use 1 switch for both the fan and light. Use another for the heat lamp. Third switch not used. This is code compliant.
Or replace the 2 wire cable.
Coastal South Carolina
Old 07-07-2013, 03:24 PM   #4
Thanks! I think I've got this figured out now. I want to replace the 12/2 cable with another 12/3, so there will be two 12/3 cables running to the exhaust fan/light. Right now the 3 switches in the bathroom have the black line in wire going to the bottom of one switch and then jumping to the bottom of the other two switches. According to the schematic if I replace the one 12/2 with a 12/3 going up to the exhaust fan/light the new black wire going to the yellow in the unit will now have to be tied into the bottom of one of the switches in the bathroom so it will always be hot, right? Thanks again for the help
Old 07-07-2013, 04:11 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Check out this diagram ( you will have to scroll down a little ) on page 3 and there is 4 differnt way you can do this.
http://www.broan.com/common/productD...2-23fc175dede4
Bon Chance .,
Merci,
Marc
Old 07-07-2013, 06:14 PM   #6
Rewards Points: 510
I would do this. Too small of a "violation". Just don't tell
Old 07-07-2013, 07:55 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What code violation?
Old 07-07-2013, 08:46 PM   #8
A "Handy Husband"
rjniles's Avatar
All conductors of a circuit should be in the same the same cable sheeth.
Old 07-07-2013, 08:57 PM   #9
E2 Electrician
Non code issue with NM type wiring methods. Of course, this probably doesnt apply to the OP, BUT, he could just cut a slot between cable knockouts and still meet code.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Any problems with this wiring diagram? fulmar2 Electrical 19 02-14-2013 06:21 PM
Is it normal to have the furnace control panel wiring, not match the wiring diagram cjbeck71081 HVAC 6 07-18-2012 11:19 AM
what is the differnce between a 35/5mfd 440 vac dual run capacitor and a 40/5 440 and does anyone have the wiring diagram. Neece HVAC 6 10-28-2010 05:51 PM
help me i need some one to draw me a wiring diagram guitarfchs78 Electrical 2 01-28-2008 05:43 PM
