Plastic Or Metal Boxes - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 10:05 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by Clutchcargo View Post
Are the adjustable boxes any good?
I love the new black ones from Arlington
It looks like there isn't a clamp in some of the plastic boxes. How do you clamp the wire to the box?
Most plastic boxes have integral clamps. Single gang boxes with no clamps or grips are fine, the cable must be stapled within 8" of the box with them though as opposed to 12" for all others.
(Sorry Brric for the correction )
Old 10-24-2010, 11:56 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Also nice gotcha if you have BX cable do not ever use them in plastic box but MC with interal grounding conductor it is not a issue as long you have proper KO fitting for it.
That is the one of few quirks you have to watch out with older BX cables but for MC and NM they are not a issue with plastique box.
If you worry about abuse or feel flimsy get hevey walled plastique box they are much stronger but not quite the same as steel box but far much stiffer I used them quite few locations where I can justify the extra cost.
Merci.
Marc
Old 10-25-2010, 06:40 AM   #18
Master Electrician
Rewards Points: 3,680
I believe if you review the newer codes the 8" requirement has be deleted.
brric is offline   Reply With Quote
Old 10-25-2010, 06:55 AM   #19
It's still in my 2008 NEC. I do not have a copy of 2011 yet.
314.17(C) Exc.
Old 10-25-2010, 05:55 PM   #20
Master Electrician
314.17(C) Exc.
You are right. I stand corrected.
Old 10-25-2010, 07:06 PM   #21
Just call me Andrew
Rewards Points: 1,020
Why don't they make a way to adapt MC cable to a plastic box? Some sort of clamp that also has a screw that holds a conductor down?
Andrew
secutanudu is offline   Reply With Quote
Old 10-25-2010, 07:11 PM   #22
Yeah there is connector for this purpourse it called MC connector it will look simauir to NM connector but in diffrent confertion which they are designed for MC/BX cables.
But to stick in the plastique box some will have KO for it and some don't so make sure you get one with KO verison { typically found in 4X4 plastique boxes but not in single or two gang nail on plastique boxes at all.}
Again watch out with BX cable if you run into make sure you keep steel box for this one the MC can go either way. as long you have grounding conductor in there.
Merci.
Marc
Old 10-26-2010, 08:47 PM   #23
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
My wife thinks I'm crazy. I bought a sample of a few boxes and installed them to the studs. After much deliberation, I'm going with metal. The material and quality of the plastic boxes do not give me the confidence that plastic will last the life of the wall. I'm thinking one receptacle replacement is all it's going to take to strip the plastic threads and then you've got a wobbly outlet. Carlon makes a heavier gauge plastic box that I would consider using, however, it's too deep. I've got 2x4 walls and I wouldn't be able to get more than 1/4" of spray foam behind it.
So, metal it is.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-26-2010, 10:02 PM   #24
So, metal it is.
I say you are WAY over thinking this.
Old 10-26-2010, 11:33 PM   #25
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Just like Petey said!
You are making a simple process rocket science!
Old 10-26-2010, 11:43 PM   #26
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Me too. I just would have used metal boxes from the get go and been done with it.
Old 10-27-2010, 09:07 AM   #27
I have gas!
You guys sound like my wife. I guess I am a little OCD about this.
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
loose outlet boxes on metal studs windowguy Electrical 7 01-29-2009 01:12 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 06:54 PM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 09:16 AM
