-   -   plastic or metal boxes (http://www.diychatroom.com/f18/plastic-metal-boxes-84790/)
Clutchcargo 10-24-2010 04:41 PM
63 Attachment(s)
I'm redoing all the electrical in my house and now deciding on plastic or metal, Is there any benefit to using plastic over metal boxes other than cost?
nap 10-24-2010 04:58 PM
Is there a cost benefit for plastic?
Personally, since I do commercial electrical work, I highly prefer steel but either is fine if installed properly.
Lockeset 10-24-2010 05:24 PM
This could be a huge argument. Ground up or down? Backstab or don't backstab? Pigtail or run thru the device? And finally- plastic or metal boxes?
IMO, and it's just that, plastic is better. It's cheaper and safer, IMO. You loose any risk of arcing to the box.
I do commercial and industrial as my profession, but when I do residential, including my own house, I always use plastic.
Speedy Petey 10-24-2010 05:28 PM
When using NM cable, in my professional opinion there is absolutely no reason to use metal boxes. :thumbsup:
brric 10-24-2010 05:52 PM
Usually metallic for heavy ceiling fixtures otherwise plastic.
Clutchcargo 10-24-2010 05:58 PM
63 Attachment(s)
Just got back from HD.
I gotta say, the plastic boxes are flimsy to say the least. When actually plugging something into the receptacle that has a plastic box behind it, are you able to tell that it's plastic? It seems like there may be a bit of flex.
brric 10-24-2010 06:01 PM
Not if it is properly installed.
kbsparky 10-24-2010 06:02 PM
A circuit cannot be shorted out if a loose terminal or bare conductor happens rest on the side of the plastic box.
Not so with a metal box, which is required to be grounded.
Clutchcargo 10-24-2010 06:33 PM
63 Attachment(s)
Are there better plastic boxes sold at other retailers or are they all pretty much the same as HD?
Jim Port 10-24-2010 07:24 PM
Carlon has a line of boxes called Super Blue that are more rigid than the standard Carlon box.
Scuba_Dave 10-24-2010 07:25 PM
I use plastic
There are heavier duty plastic boxes at HD too
But I bought a complete box of 100 plastic boxes
If I needed more then 60 (I think) it was less $$ then buying a few at a time
Speedy Petey 10-24-2010 07:26 PM
I was going to post exactly this. HD and Lowes are not the end-all places to buy this stuff.
I will say though, the heavier blue boxes that they sell are not at all that bad, albeit pretty expensive.
Clutchcargo 10-24-2010 08:17 PM
63 Attachment(s)
Thanks, I'll go back and take another look or check another store.
Couple questions about the plastic boxes...
Are the adjustable boxes any good?
It looks like there isn't a clamp in some of the plastic boxes. How do you clamp the wire to the box?
brric 10-24-2010 08:24 PM
Single gang boxes require the cables to be stapled within 12" of the box. Multigang boxes have integral cable clamps.
Red Squirrel 10-24-2010 08:44 PM
I use metal just because it's much easier to find. The only plastic boxes I see at the hardware store are the outside ones that have screw on conduit fittings.
I've never worked with plastic boxes, so can't say if I like em better or not. Metal seems more "rugged" though.
