Plasma Cutter Hook Up Three Phase Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 06:20 PM   #1
Hi Guys new here
I Was looking at getting plasma cutter, for my shop.
Shop still has old style fuse box set up.
Specs:
240v three phase 200A service
I was just wondering if I be able to run a industrial 400-460V - 3 phase machine on the 240v, Or would I only be able to power 230v three phase or single phase machines on my setup?
If you could give me some options I'd appreciate it.
Thanks nick
Refuse&Welding is offline   Reply With Quote
Old 04-02-2012, 07:08 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Unless you can change the voltage on that cutter, you will have to go with a 240 v. single or 3 phase.
You could also do a step up transformer, but that cost be costly.
jbfan is online now   Reply With Quote
Old 04-02-2012, 11:56 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
That must be a big plasma cutter....the one I have uses 120Vac...
Old 04-03-2012, 12:01 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
You certainly can run it, but you will need a transformer. The transformer may be quite expensive, depending on the current requirements. If you're buying used equipment, the cost of the transformer will probably be similar to the cost of the plasma cutter. You'll be better off with a 240V machine.
mpoulton is offline   Reply With Quote
Old 04-03-2012, 07:51 AM   #5
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What thickness steel will that do? I have been looking for a small plasma cutter. We have a large unit at work but would be nice to get one for home.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-03-2012, 07:52 AM   #6
joed's Avatar
Rewards Points: 12,862
If your shop is three phase it is likely that you have 208 volts not 240 volts. It could make a difference in the performance of the cutter.
Old 04-03-2012, 12:45 PM   #7
Thanks for the replies!
I guess be better off looking into a dual phase machine
Single or Three phase
208/230v
It says 240v on the main box and on the meter the 240 is whats lite up.
Old 04-03-2012, 12:56 PM   #8
jbfan's Avatar
Rewards Points: 478
You must have a high leg delta system then.
Old 04-03-2012, 02:05 PM   #9
I have a Miller Spectrum 375 Extreme. I like it a lot. It runs on anything from 120 to 240V and is lunchbox sized. Cuts 1/4" just fine and 3/8" slowly. The ability to use any 120V source at reduced power or use 240V and crank up the current is really useful.
3 phase power phase question jelliott Electrical 16 12-20-2008 03:21 PM
3 Prong Range Hook up question tulsa442 Electrical 20 04-15-2008 09:58 PM
Plasma Cutter groman48 General DIY Discussions 1 03-11-2008 05:35 PM
New W Meter Hook Up Question wannabuild Plumbing 2 02-01-2007 11:16 AM
3 phase panel question curse21 Electrical 2 08-18-2004 10:17 PM
