Plan On Turning An Existing Light Circuit Into 3way? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 01:57 PM   #1
Question
Plan on turning an existing light circuit into 3way?
Ive currently got my feed from the panel and wire to the light at my single switch and was wondering what connections were required if i planned on changing that to a 3way switch with another on the other side of the room? Can this be down by just running a 3 wire between the switches or does either the feed or light have to be at the other switch? I understand how to do it that way but was kind of hoping to leave the existing wires run. Thanks.
mj876 is offline   Reply With Quote
Old 08-30-2010, 02:10 PM   #2
Question
I don't know if this will help you understand what i am trying to work with or not.
Old 08-30-2010, 02:23 PM   #3
Licensed electrician
Rewards Points: 1,020
It is possible to wire this as a dead-end 3 way. Splice the incoming power to the white of the 3 wire + ground cable. this is your Common. Place the outgoing black on the Common of the 3 way switch at the original location. Black and red of new cable to traveler terminals of both switches. Re-identify the now hot white with black tape or magic marker at both ends.
mj876 (08-30-2010)
Old 08-30-2010, 05:00 PM   #4
This will function exactly like a normal 3way switch?
Old 08-30-2010, 05:02 PM   #5
There will be no difference.
Old 08-30-2010, 06:28 PM   #6
Alright i think i got it.
Old 08-30-2010, 06:43 PM   #7
Is this what you mean? I used blue to represent the white wire and the colored-in terminals represent the commons.
Old 08-30-2010, 06:51 PM   #8
Rewards Points: 1,418
Yes, the diagram immediately above is correct.
Old 08-30-2010, 06:55 PM   #9
Alright thanks alot guys.
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Branching off existing circuit schnitz411 Electrical 13 03-14-2010 11:11 PM
outdoor light fixture kills everything on circuit kramwens Electrical 10 10-10-2009 04:50 PM
Adding 15 amp light and switch on a 20 amp circuit Jzack26 Electrical 1 08-02-2009 05:02 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
