Placement Of Stair Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 01:45 PM   #1
Rewards Points: 270
Placement of stair lighting
The landing upstairs is dark wood and at night it's challenging to see where the stair begins. Would one get a good sense of when to step but placing some light on the step, say under the overhang? Or should the light shine on the landing, just before the step?
I can't really visualize it.
puttster is offline   Reply With Quote
Old 01-01-2013, 01:59 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
Are you looking for a ceiling light, or wall lights to shine on the steps?
jbfan is online now   Reply With Quote
Old 01-01-2013, 02:01 PM   #3
Rewards Points: 6,652
If Ceiling, it should be shining down. If you want accent lighting along the stairs, so you can have the overhead off, if going from living area, to living area, you would have to cut into the drywall to pull the wiring for those. Really need a better picture showing the whole stairwell, not just the last step & landing.
Old 01-01-2013, 04:55 PM   #4
Licensed electrician
Rewards Points: 1,296
A ceiling light will give much better lighting to the whole staircase.
Old 01-01-2013, 05:59 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,904
For stair lights specifically, LED strips under the overhang of each step are pretty good. That would light the top step, but not the landing itself. A ceiling light would be best for the whole area though.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-01-2013, 06:00 PM   #6
Rewards Points: 270
The landing has a ceiling light that does a pretty good job, when and if it is turned on. I was looking for some always-on accent lighting, probably DC? Problem is I don't know where to place it where it would better define the edge of that first step. The first one is the tough one.
Old 01-01-2013, 06:04 PM   #7
Maybe talk to a real lighting specialist, not someone in a Orange apron.
Old 01-01-2013, 08:00 PM   #8
LED strip under the overhang of the landing would probably work best. It will look nicest if you do it on every step, but that's a lot of work.
Exterior Soffit Lighting - Please Help with Light Placement RedRX Electrical 1 01-10-2012 07:40 PM
Recessed Lighting Placement monkeystomach Electrical 6 03-10-2010 08:29 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 06:18 AM
Stair lighting question...help! Mary Ann Electrical 2 11-04-2008 12:21 AM
Recessed hall and stair lighting, where? bjherron Electrical 1 09-26-2007 01:18 AM
