Placement Of GFIC - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2006, 06:03 AM   #1
Placement of GFIC
Hello Everyone,
Need advice on the location/placement of a GFIC Outlet in a half bathroom. Is there a code or guidelines where I need to place the GFIC??
I have (2) walls where I can put it. One is an inside wall and the other is an outside wall. No problem drilling a hole thru the floor to run the wire to the panel.
Also, is the a height restriction for the GFIC?? Should it be so high off the floor or so high off the vanity??
Thanks, Allen
allen1466 is offline   Reply With Quote
Old 03-23-2006, 07:14 PM   #2
Remodeler
MinConst's Avatar
If you have a duplex outlit in the bathroom now juts replace that with a GFCI outlet. If you need to add outlets to the bathroom they all need to be protected.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 03-24-2006, 05:46 PM   #3
Electrical contractor
RobertWilber's Avatar
Per NEC 210.52 [D] says that a receptacle shall be installed within 3 feet of the outside edge of the sink basin on a wall or partition adjacent to the basin or countertop.
Common height is about 43"
RobertWilber is offline   Reply With Quote
Old 03-24-2006, 08:46 PM   #4
Contractor
My sparky tells me that it is within 6' but that may be a local code. The easiest way out is to go with a breaker, then everything is covered.
Teetorbilt is offline   Reply With Quote
ac suction line placement? nimbenja HVAC 8 10-28-2009 05:43 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
window placement ? nes Building & Construction 8 07-19-2007 09:15 PM
roof sheathing placement dmend Roofing/Siding 1 03-20-2006 09:03 PM
