Placard For Back-fed Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 09:57 PM   #1
I ask the impossible!
Rewards Points: 692
Placard for back-fed panel?
While I did pass my inspection, my inspector wanted me to make some changes on my water pipe bonding. I had 1 wire going from the panel, then to both sides of the meter ending on the hot pipe out of the water heater. He wanted me to just cut that wire after the house side of the meter then use the wire to go bond the hot pipe to cold pipe to the gas pipe at the water heater. No problem there I understand and it's done.
His other condition is he wanted me to put a placard at both the old meter and new meter and old and new panel stating that there is a backfed panel. He said the POCO would most likely connect the new 200A panel before disconnecting the 100A panel, and he wanted to be sure they were aware there is the potential that the load side at the 200A socket could potentially be live.
The POCO isn't making the connections tommorrow, but they are sending someone out to look at the setup. Is there a sign I can buy at an electric store, or is this just a piece of paper with wording like "CAUTION: BACK-FED PANEL"
When I searched for backfed warning placard, the search results all related to solar power set-ups.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-23-2011, 01:46 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Oui.,
You can make a tempory sign to warn someone that is backfeed source so they will know.
Merci,
Marc
Old 06-23-2011, 02:48 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,938
If the old panel is going to be removed, I'd just write on it with a sharpie in big letters. Otherwise, a hand-written note on a piece of paper duct taped to it should be fine. It's a good idea.
mpoulton is offline   Reply With Quote
Old 06-23-2011, 09:51 AM   #4
Rewards Points: 121
This may help: http://www.mysafetysign.com/Safety-S...KU-S-1155.aspx
jrepp44 is offline   Reply With Quote
Old 07-11-2011, 09:18 AM   #5
A trophy shop should be able to provide you a placard
We solar contractors have to get placards made up all the time. We use trophy shops. Each placard is about $5 when ordered in bulk so yours would probably be twice that. Instead of calling trophy shops first, perhaps call a local solar contractor and ask which trophy shop they use, this way the trophy shop operator is already familiar with the setup, letter heights, et cetera.
Blue Skies, Jeff
That Solar Guy is offline   Reply With Quote
Panel cleanup gdoucette Electrical 5 06-26-2010 02:01 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
