Pilot Light Switch With Two Black, Two White And A Red Line. Lost? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 11:36 PM   #1
Pilot Light Switch with two black, two white and a red line. Lost?
When I removed the existing switch the whites and blacks were both on one mount. Can't remember the red location. New switch has a brass and silver on one side and a black and ground on hte other. Any help?
Summit Joe is offline   Reply With Quote
Old 08-13-2011, 07:24 AM   #2
Rewards Points: 1,442
Connect both whites to the switch neutral terminals (usually silver).
Connect both blacks to the always hot terminals.
Connect the red to the switched hot terminal.
Connect the bare wires (if any) to the ground terminals.
If two wires want to go under one screw, cut a short length of wire (pigtail) of the same color (black and red interchangeable, green and bare interchangeable) and connect that to the screw. Connect the two ends in question to the other end of the short length using a wire nut.
It is not a good idea to take things apart without labeling the wires.
AllanJ is online now   Reply With Quote
Light switch only has 1 white and 1 black wire? kango86 Electrical 29 01-04-2017 08:58 PM
Light Switch With 5 Wires, Black, White, Red, Wtf? ts46176 Electrical 15 07-25-2011 08:41 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
