Pigtails Vs Daisy Chains??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 06:57 PM   #1
Pigtails vs Daisy Chains???
I've done a ton of searching on this site and can't really find a difinitive answer. If I'm installing a chain of 5 outlets in my garage, what is the proper way to do so- pigtail each incoming and outgoing conductor leaving only one black and one white connected to each outlet. Or just making mulitiple connections on each outlet? My outlets have both screw type connectors, and stab-in connectors.
What are the pros and cons of doing it either way?
THANKS!!!
mopowers is offline   Reply With Quote
Old 03-14-2010, 07:03 PM   #2
Learning by Doing
Leah Frances's Avatar
If you've search this site I'm sure you found many of the great threads that address this issue.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-14-2010, 07:08 PM   #3
Master Electrician
Rewards Points: 3,920
Pigtailing makes future troubleshooting much easier.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
mopowers (03-14-2010)
Old 03-14-2010, 07:09 PM   #4
Sorry for the repeated question. I finally found this very helpful thread: Wire Recepts. in Series or Parallel?
I'm not too good with the search function. Thanks.
Old 03-14-2010, 07:11 PM   #5
Question
...And the majority? of those threads and posts are in favor of pigtailing. I personally prefer pigtailing (switches, too.) Just for the simple fact, that if you have a break in the wire at one receptacle all the others are not affected. But "Daisy chaining" also has its advantages. If you want to give Ground fault protection, in a daisy chain connection, all receptacles that are "Downstream" of the first one are protected.!
spark plug is offline   Reply With Quote
Old 03-14-2010, 07:14 PM   #6
Rewards Points: 506
What do you mean when you say you prefer to pigtail a switch? What other method would be less preferred? I'm confused.
jlmran is offline   Reply With Quote
Old 03-14-2010, 07:20 PM   #7
Unhappy
Originally Posted by jlmran View Post
How do you pigtail a switch?
When you're dealing with Two or more switches, some electricians like to take one long wire (feed wire) and skin off the insulation where it meets the power side of each switch. The other method is "Pigtailing" (not the exact term) each switch and twisting with a wire nut to the "Feed".!
Old 03-14-2010, 07:23 PM   #8
Rewards Points: 506
Got it...makes sense.
Old 03-14-2010, 08:58 PM   #9
MWBC's require pigtail on the Neutral under NEC 2008
Old 03-14-2010, 09:56 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Good point Dave, but as long as I can remember, it has been required.
Extra wire to do pigtails for outlet...splice romex? RyanD Electrical 3 05-12-2009 11:05 AM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 11:20 AM
Installing 20 amp circuits in metal boxes, is 14 ga OK for ground pigtails? thegonagle Electrical 17 11-14-2008 07:34 AM
pigtails in Canada rtoni Electrical 13 07-24-2008 11:02 AM
Ceiling fan pull chains CowboyAndy Electrical 3 03-12-2008 06:02 PM
