Are Pigtails Ok In The Electic Panel??? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 09:12 PM   #1
Are pigtails ok in the electic panel???
I am finishing off my basement and added several circuits to my main box. The previous home owner had switched the dryer & stove over to natural gas from electric, so I removed what I thought were "unused" circuits when I added the new lines for the basement. (I actually just taped them off with electrical tape and left them inside the box).
Turns out, that one of the circuits I removed was for the air conditioner, so I need to add that circuit, but need to put it in a different spot within the box from where it had previously been. I have room for it, but I need to make the wires about 8" longer so they will reach to their new space in the box.
Doesn't seem like pigtailing 10-guage wire is a good idea, but I am not seeing anything over the internet that says I cannot do it.
tomkatz is offline   Reply With Quote
Old 05-25-2009, 09:19 PM   #2
300zx's Avatar
Post
Yes you can use pigtails in electic panel
300zx is offline   Reply With Quote
Old 05-25-2009, 09:25 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You certainly can do it. Just make sure your splices are sound. It is not as easy for a DIYer to splice #10 as you might think.
Old 05-25-2009, 09:53 PM   #4
Rewards Points: 6,652
Why not move the other circuit that the A/C breaker was in orginally? It is simpler to pigtail #12 or #14, then #10, #8, #6.
Old 05-26-2009, 03:10 PM   #5
Rewards Points: 58
Try these. Perfect for this job. Yellow for #10.
J. V. is online now   Reply With Quote
Old 05-26-2009, 05:39 PM   #6
Dont use these connectors, you more than likely have solid #10 copper conductors. They dont work worth a hoot on solid wire. Just use wirenuts.
unclduey is offline   Reply With Quote
Old 05-26-2009, 07:53 PM   #7
Registered User
Termite's Avatar
Great for car stereos and trailer lights, but I have yet to ever seen an electrician use one of them on household wiring. I'd be really curious to see a listing on them to see if they're intended for that application. I might be proved wrong, but I'd definitely question it.
A wire nut or a Wago Wal-nut would be more appropriate I'd think.
Old 05-27-2009, 01:41 PM   #8
Rewards Points: 58
Well you did ask a good question. The UL listing number is E9809. #12 and smaller, solid wire is acceptable and listed. #12 wire and larger, only stranded. So, OP do not use these on #10. Learn something new every day. Thanks John
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Pigtails inside a Panel Gusaroo Electrical 27 03-19-2008 12:28 PM
