Pigtailing Wall Switches, Ceiling Lights, Etc. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 01:13 PM   #1
Pigtailing Wall Switches, Ceiling Lights, etc.
I have a 1971 3-bedroom cape with the infamous AL wiring. I was in the process of replacing all the AL wiring throughout the entire house but decided not to (way to time consumming). Instead, I am now going to pigtail all house receptacles and use the expensive purple caps. Question is, should I followup using the same process for wall switches, ceiling light attachements, and circuit breakers as well? Not sure how far an electrician would go in correcting this issue short of replacing the AL wire with CU. Any comments would be appreciated.
Rich Gill is offline   Reply With Quote
Old 02-12-2013, 02:09 PM   #2
MCB
sparky
Yep. Every outlet, fixture, everything. Very specific method for the splicing and materials for pig tailing the AL to CU. There can be no cuts or marks on the AL as it creates excessive heat on the connection. Use the proper compatible connector (Marrette 63?) and the anti oxidant.
For us here in Canada, anyway. Seems to be some insurance co.'s pushin it.
MCB is offline   Reply With Quote
Old 02-13-2013, 06:36 AM   #3
Thanks for the info. More work but wanta get it right first time.
Old 02-13-2013, 06:40 PM   #4
Licensed electrician
Rewards Points: 1,634
Try the Alumi-conn connector instead of the Ideal purples. Or change the devices to CO/ALR rated ones.
No change is needed at the breakers.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
MCB (02-13-2013), NJMarine (02-14-2013)
Old 02-14-2013, 06:10 AM   #5
Thanks for the info. Jim.
Old 02-14-2013, 11:41 AM   #6
Rewards Points: 168
Like these.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 10:26 PM
ceiling rose to pot lights gee398 Electrical 8 09-03-2010 10:46 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
