Pigtailing For Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2008, 11:41 AM   #1
Rewards Points: 150
Pigtailing for lights
Hey, I have a question about pig tailing for lights. I have four lights I have to power from one feed. The feed starts in the 4 gang box, and there are four sets on NM going to each light . Can I put four pigtails to the hot feed to feed each switch. That would be a total of five conductors under one nut. I would use the right nut of course.
James Con is offline   Reply With Quote
Old 08-02-2008, 12:15 PM   #2
joed's Avatar
Rewards Points: 12,874
No pigtails requitred here. Simply connect the wires from the switch cable to the power cable and the light fixture cables.
Old 08-02-2008, 01:56 PM   #3
Contractor - Renovations
fungku's Avatar
Yes.
fungku is offline   Reply With Quote
Old 08-03-2008, 07:56 AM   #4
Rewards Points: 150
Each light is going to be controlled by it's own switch. Four switches total.
Old 08-03-2008, 08:38 AM   #5
joed's Avatar
Mis read your first post.
Yes connect four pigtails to the feed power hot wire. Then connect one pigtail to each switch.
Old 08-03-2008, 08:39 AM   #6
electrical contractor
Rewards Points: 150
That leaves you with 6 grounds if you are using a metal box, not a problem with the correct wirenut.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 08-03-2008, 05:49 PM   #7
Rewards Points: 150
Cool, For my future reference what's the max. # of pig tails allowed to feed off a hot. With the right wire nut and box.
Old 08-03-2008, 06:35 PM   #8
fungku's Avatar
I very highly doubt you'll ever run into that situation.
I think you'd run into the issue of having too many wires entering the box first.
Old 08-03-2008, 08:26 PM   #9
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
There is no limit in the electric code. And wires which do not enter or leave the box (pigtails) are not counted for box fill.
John
jrclen is offline   Reply With Quote
Old 08-03-2008, 11:29 PM   #10
Rewards Points: 150
