Pigtailing 12-2 To 14-2 - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 07:54 AM   #16
Rewards Points: 1,532
Originally Posted by htae View Post
Your #14 AWG pig tails would be acceptable with a #12AWG circuit. As long as your hood is within three meters of the splice and is of adequate size to carry the load of the hood (which it would be unless it's a fancy industrial type) This is considered a tap conductor and is deemed acceptable by code. However, it would make more sense to hardwire it with #12 since its already on a 20 amp breaker. But to answer your question. That would be acceptable. Its no different than installing a light that comes with #16AWG
Unless things have changed, I read that the maximum length of a tap conductor is around 14 inches. About the length of the lead from the junction box of a recessed ceiling light to the lamp socket.
Old 04-14-2013, 08:06 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is this from the CEC? This is not correct based on the NEC.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Speedy Petey (04-14-2013), stickboy1375 (04-14-2013)
Old 04-14-2013, 09:16 AM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Code reference?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 04-14-2013, 09:17 AM   #19
E2 Electrician
Originally Posted by rjniles View Post
I would install a short appliance cord on the hood and plug it into the existing receptacle.
The receptacle would have to be supplied by a dedicated circuit if you were to choose that option.
Old 04-14-2013, 11:58 AM   #20
Rewards Points: 31
Originally Posted by stickboy1375 View Post
Code reference?
CEC 14-100 subrule b
htae is offline   Reply With Quote
Old 04-14-2013, 12:00 PM   #21
E2 Electrician
Only problem is.... where is the OP's location?
Old 04-14-2013, 12:09 PM   #22
Rewards Points: 31
Op's?
Old 04-14-2013, 12:12 PM   #23
E2 Electrician
Op's?
OP = Original Poster
Old 04-14-2013, 12:23 PM   #24
Rewards Points: 31
Fair enough. I don't know the location, but it would meet code if it's in Canada
Old 04-14-2013, 12:25 PM   #25
E2 Electrician
Don't worry, i've been burned on this scenario before myself.
I was just pointing it out.
Pigtailing Wall Switches, Ceiling Lights, etc. Rich Gill Electrical 5 02-14-2013 11:41 AM
New outlets instead of pigtailing Roro13 Electrical 26 06-30-2012 04:45 PM
Pigtailing for a freezer Hrose77 Electrical 7 04-20-2011 12:52 PM
Help - Adding a third outlet off of 1 outlet, shallow box so no pigtailing stlramscards Electrical 20 02-01-2011 07:52 PM
Pigtailing for lights James Con Electrical 9 08-03-2008 11:29 PM
