Pigtailing 12-2 To 14-2 - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 01:52 PM   #1
Pigtailing 12-2 to 14-2
I removed a microwave above my range to replace it with a 120 volt rated range hood. The hood has to be hardwired. In the cabinet above the hood there is an outlet which the micro was plugged into. It's a homerun to a 20 amp breaker. Can I leave the 20 amp breaker wired with 12-2 and pigtail in the box above the range with 14-2 to attach to the range hood?
rcuchel is offline   Reply With Quote
Old 04-05-2013, 01:53 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,858
No. Why would you use #14 for the pigtail? It needs to be #12 if it's on a 20A breaker.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-05-2013, 01:55 PM   #3
ok, but is it ok to leave the 20 amp breaker in the box even though the range hood doesn't require it?
Old 04-05-2013, 02:30 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Yes...
Old 04-05-2013, 03:06 PM   #5
Thanks, and one more question: The #12 wire that I pigtailed in the box in the cabinet now has to be connected to the range hood. I know that the wiring already exists in the range hood and is rated for 120VAC. Directions say to connect the range hood wires to the house wire. Will that be a problem since I have #12 going back to the 20 amp breaker?
Old 04-05-2013, 04:41 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would install a short appliance cord on the hood and plug it into the existing receptacle.
Coastal South Carolina
Old 04-05-2013, 04:56 PM   #7
Thenks, but I was told to hardwire the hood, and I just want to make sure I don't have to change the breaker, and make sure going from my #12 pigtail to the hood wiring is ok.
Old 04-05-2013, 05:05 PM   #8
If you have shelf above the good, it wouldn't hurt to leave the outlet. Then you can plug in any other electronic devices in the future (radio, transformer for under cab lighting, etc).
sparkyjake is offline   Reply With Quote
Old 04-05-2013, 05:18 PM   #9
No, there is a cabinet above the hood, and that's where the box is. There is no receptacle, I'm hardwiring. I just want to make sure I can hardwire the hood's wiring to the #12 wire on the 20 amp breaker.
Old 04-05-2013, 07:42 PM   #10
Rewards Points: 506
What's your concern? #12 is rated for 20 amps, therefore, a 20 amp breaker is required.
Do NOT use a #14, however, as per your first request.
Are you concerned about the size of the range hood's wiring? Don't be.
Old 04-05-2013, 10:21 PM   #11
Yes, that's exactly what I was concerned about. Thank you. Finally someone has answered my concern. I appreciate it.
Old 04-05-2013, 10:32 PM   #12
jbfan's Avatar
Rewards Points: 142
Didn't I answer the question in post #4?
Old 04-06-2013, 08:21 AM   #13
I thanked you for answering my question in post 3 and then posed another regarding connecting the wiring from the range hood (which is not as heavy as the #12 from my box) to the 12wire of my pigtail. Sorry for the misunderstanding and thanks for your reply. It was in fact helpful.
Old 04-06-2013, 03:03 PM   #14
Rewards Points: 506
To be honest, you didn't actually point out the concern with the range hood fixture wires; I took a guess.
It is OK to connect the two.
Old 04-14-2013, 01:23 AM   #15
Rewards Points: 31
Your #14 AWG pig tails would be acceptable with a #12AWG circuit. As long as your hood is within three meters of the splice and is of adequate size to carry the load of the hood (which it would be unless it's a fancy industrial type) This is considered a tap conductor and is deemed acceptable by code. However, it would make more sense to hardwire it with #12 since its already on a 20 amp breaker. But to answer your question. That would be acceptable. Its no different than installing a light that comes with #16AWG
htae is offline   Reply With Quote
Pigtailing Wall Switches, Ceiling Lights, etc. Rich Gill Electrical 5 02-14-2013 12:41 PM
New outlets instead of pigtailing Roro13 Electrical 26 06-30-2012 05:45 PM
Pigtailing for a freezer Hrose77 Electrical 7 04-20-2011 01:52 PM
Help - Adding a third outlet off of 1 outlet, shallow box so no pigtailing stlramscards Electrical 20 02-01-2011 08:52 PM
Pigtailing for lights James Con Electrical 9 08-04-2008 12:29 AM
