Piggy Backing Off GFCI Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 08:02 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes, you would need a separate neutral from the load side of the GFI.
The Following User Says Thank You to k_buz For This Useful Post:
miamicuse (06-05-2012)
Old 06-05-2012, 08:46 PM   #17
Sparky
Rewards Points: 510
you would need a 2nd neutral if the Sconces werent GFI protected, yes.
Techy is offline   Reply With Quote
Old 06-05-2012, 08:50 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Unhappy
Originally Posted by miamicuse View Post
One more question about this topic.
Let's say I have four boxes all in the bathroom, the conduit runs from Box 1 to 2 to 3 to 4. They are actually fairly close to each other, but due to framing and piping in the way, the conduits run up to the attic and back down as it hops from box to box.
Box 1 - Sconce switch and GFCI outlet.
Box 2 - Sconce 1
Box 3 - Sconce 2
Box 4 - Outlet, end of run
I have a neutral wire that runs from box 1 to 2 to 3 for the sconces.
However, since I am piggybacking the outlet in Box 4 on the GFCI outlet in Box 1, I need to run a special neutral wire coming out of the LOAD side of the GFCI outlet in Box 1, all the way to Box 4 for that outlet right? I can't just splice off the neutral for the sconce in Box 3, I don't think.
Just wanted to make sure. Thanks.
You do not need a seperate neutral in this scenario. From the first box you need 3 wires- hot: switched hot: neutral. The 3 wires orginate from the load side of the GFCI. The switched hot thru the switch.
Coastal South Carolina
Old 06-05-2012, 08:50 PM   #19
k_buz's Avatar
Only if the sconces are on the load side of the GFI. I didn't see any indication that they were.
Old 06-05-2012, 09:37 PM   #20
Rewards Points: 1,628
They are not.
miamicuse is offline   Reply With Quote
Old 06-05-2012, 09:55 PM   #21
A "Handy Husband"
rjniles's Avatar
They are not.
I thought thr sconces were on the load side. If not you need a swiched hot and a neutral off the line side for the scones and a hot and neutral off the load side for the recep.
Sorry for the confusion.
GFCI Breakers vs. Outlets michaelson Electrical 2 03-23-2012 05:59 PM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
When I add my GFCI outlets....... nateshirk Electrical 11 05-04-2011 09:07 PM
Problem with GFCI Outlets in Kitchen mkrawitz Electrical 13 04-14-2010 08:35 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
