Piggy Back From Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 01:33 PM   #1
Piggy back from gfci
I am trying to wire in a dual switch to run my bathroom light, and the exhaust fan from. I have already put in a new GFCI, have power to both outlets, now how do I get power from it to the dual toggle switch?
ohiofan_2 is offline   Reply With Quote
Old 02-27-2013, 01:42 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
If you want the fan and lights gfci protected, bring a jumper for the load side to the switch.
If you do not want them gfci protected, bring a jumper from the line side to the switch.
Old 02-27-2013, 01:47 PM   #3
It really doesn't matter to me if they are. My concern is getting power to the 1 piece, 2 switch outlet to run the fan off one and the light off the other. I think it would be best protected. The switch that I bought has 4 of the same color screws, so determining hot or not may take some time. Thanks.
Old 02-27-2013, 01:47 PM   #4
Is there any pages that give a diagram of what I amtrying to do as a reference
Old 02-27-2013, 01:50 PM   #5
jproffer's Avatar
Rewards Points: 716
Sounds like you bought the wrong switch. A single pole (single location) switch should have 2 screws.
jproffer is offline   Reply With Quote
Old 02-27-2013, 01:52 PM   #6
jbfan's Avatar
Rewards Points: 650
Post the model number of the switch you bought.
Old 02-27-2013, 01:53 PM   #7
I have a 2 toggle, over and one under, with poles on each side. It said that it was a multi unit (light and fan) type useage. Your saying that I need a single poled switch?
Old 02-27-2013, 01:57 PM   #8
jbfan's Avatar
Rewards Points: 650
The switch should have two screws on one side that may be close together or attached to each other with a copper tab.
This will be the side the power comes into the switch.
The screws on the other side should be located at the top and bottom, and this would be the feed to each light.
The Following User Says Thank You to jbfan For This Useful Post:
ohiofan_2 (02-27-2013)
Old 02-27-2013, 03:13 PM   #9
690-wgcc6. 1 pole
Old 02-27-2013, 03:41 PM   #10
Rewards Points: 44
Follow jbfans directions in the post above. One switch will control the light and the other will control the fan. What kind of wire do you have running from the light/fan to the switch? How many conductors?
djlandkpl is offline   Reply With Quote
Old 02-27-2013, 03:45 PM   #11
After I got to look at it yes there is a copper tab connecting two of the poles. So the hot goes to one, does the white go to the other? On the other side for light and fan?
Old 02-27-2013, 03:51 PM   #12
jbfan's Avatar
Rewards Points: 650
The white connects to the white wires that go to the light and fan, and not on the switch.
Old 02-27-2013, 04:06 PM   #13
So connect all the whites together, but not to any of the poles...the blacks will be connected to the switch that I want operating whichever (light or fan). Yes/no. I have a good idea how to do this, just need to ne sure I'm doing this right.
Old 02-27-2013, 04:10 PM   #14
jbfan's Avatar
Rewards Points: 650
Correct.
Old 02-27-2013, 04:37 PM   #15
Now that I can get to work on it. Blacks to pole side with power in, or opposite that's not connected by by tab?
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI troubleshooting XwpisONOMA Electrical 20 11-13-2011 05:19 PM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
