Pig Tails - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 11:02 AM   #1
Rewards Points: 1,648
pig tails
They sell those green pig tails and they are solid conductors.
Any reason they are solid? Is using stranded green wires the same?
Also, if the metal box is against a concrete block, and it's an old box that does not have a "raised" section for the green screw, is it OK to use those clips? Do you clip it to the inside edge of the mud ring?
miamicuse is offline   Reply With Quote
Old 12-28-2013, 11:15 AM   #2
Licensed electrician
Rewards Points: 1,870
A mud ring does not have enough flat surface to properly install the clip.
Old 12-28-2013, 12:25 PM   #3
OK good point, I assume those are meant to clip on the sides of the metal box before the mud ring is put on, so for an existing installation where the sheetrock is already covering up the edges of the mud ring and it can't be removed to install the clip, these clips are not going to be useful.
I guess the only option is to use a concrete drill to drill a hole behind the box to accommodate the green screw?
Old 12-28-2013, 01:03 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
Cut the green screw with a screw cutter.
The Following User Says Thank You to jbfan For This Useful Post:
Cletis (12-29-2013)
Awning Attached to Rafter Tails? Davio Building & Construction 0 09-14-2013 07:14 PM
rafter tails gulleyj Roofing/Siding 3 08-24-2013 11:12 PM
painting rafter tails after washing gulleyj Painting 1 08-20-2013 08:51 PM
Rotting rafter tails and fascia dave11 Roofing/Siding 1 10-20-2009 11:52 AM
