PICTURES - Confused Over Double Light Switch Wiring - Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 07:33 PM   #1
PICTURES - confused over double light switch wiring - help!
Hi all,
I am trying to replace a double light switch with fancier switches (movement detectors) but I am quite the novice. I have switched off the power on the main board, but I am lost as to where to connect what, and don't understand why the two switches are connected together with a "bridge". and what's that red wire?
any help would be appreciated. (see pictures below)
brightlight is offline   Reply With Quote
Old 07-21-2012, 07:49 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The black wire that goes from one switch to the other is the hot, the wires on the top terminals are the switch leg.
The black on the motion sensor to the hot. The red on the motion sensor to the red. The whites of the motion sensors to (all) the whites in the switch box. The blue gets capped.
The Following User Says Thank You to k_buz For This Useful Post:
brightlight (07-21-2012)
Old 07-21-2012, 07:53 PM   #3
Rewards Points: 1,442
Cables 1 and 3 -- One is the power feed and one is continuation of power somewhere else such as some receptacles.
Cable 2 -- Black wire is for light 1 and red wire is for light 2.
All cables -- White is neutral and all the whites are tied together.
Blue wire nut in forground bridging the two switches together is to convey the incoming power to both switches and all the way around to the continuation cable.
New switch -- Connect switch black to the feed and continuation blacks in the box. Connect switch red to cable 2 black. Connect switch white to the cluster of whites already there.
Second new switch, connect switch red to cable 2 red.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 07-21-2012, 08:19 PM   #4
thanks for the replies...
I'm sorry to say I'm not 100% what I'm supposed to do here, both scenarios look different to me (I'm really new at this)
my understanding is that you're "optimizing" the original wiring scheme, correct?
so here are my follow-up questions:
1. Allan, what do you mean by light 1 and light 2? is light 1 the single light and light 2 the combination of fan and double light fixture?
2. how do I figure out which one is the feed and which one is the continuation cable out of the two cables?
3. I noticed the "bridge" cable is actually the same black cable which is just stripped, twirled around the terminal, then sent to the blue nut. how will I achieve this with my new switches (three wires in a nut? is that safe?)
4. why am I connecting a white cable to the group of white cables in the box if there was no white cable going from a switch to white cables in the box before?
thanks!
EDIT: also, shouldn't the hot wire from switch 2 be connected to the hot wire from group formed by the source, continuation cable and switch 1 as well?
Old 07-21-2012, 08:40 PM   #5
joed's Avatar
Rewards Points: 11,998
1. You have two switches, light one and light two.
2.The one stripped in the middle feeding the two switches is the feed. It doesn't matter really which is the feed and which is the continue through. They get connected together so they are the same.
3.Connect the the two existing black wires with the black wires from the switches using a nut.
4.Your new switch needs a neutral connection to work. That is why the whites get connected to the other whites.
FYI "Cable" is an assembly with a bunch of wires. The labels should more properly be called cable 1 cable 2 cable 3.
The black one stripped in the middle connected to the two switches is "wire"
The Following User Says Thank You to joed For This Useful Post:
Old 07-21-2012, 08:55 PM   #6
IT WORKS!
Thank you so much.
I have another switch to do, this one a 3-way, so I might follow-up with more questions... and pictures lol
Thanks a bunch.
Old 07-21-2012, 10:24 PM   #7
OK. Here's another one for you.
I'm sure this one's easy. Basically this light dimmer switch controls two separate overhead halogen lights. One switch, two lights.
My new dimmer switch is of the same kind as the other new switches I just installed. It needs a neutral wire. My thinking is either:
1. The white wire is the wire going to the lights, and I don't have a neutral wire, in which case... what do I do????
or
2. The white wire is a neutral wire, and I don't need a wire going to the lamps because i'm at the end of a circuit?? ... lol.
EDIT: btw, this is not the 3-way I was talking about in my previous post.
Old 07-21-2012, 10:30 PM   #8
k_buz's Avatar
In this situation the white is not a neutral. This is your standard "switch loop". The white (is supposed to) be the hot and the black is the switch leg. The white should be remarked with black tape or black marker. There is no neutral in the box.
Old 07-21-2012, 10:34 PM   #9
so what you're saying is in this scenario, the white is the hot instead of the black?
and so no neutral... what do I do? the instructions that came with the dimmer say it needs a neutral... is it optional??
EDIT: btw, how did you know the white and black were inverted? how can I know next time?
Old 07-21-2012, 10:41 PM   #10
k_buz's Avatar
If there is no neutral in that box, you will either not be able to use that dimmer or you will need to run a new wire from the switch box to the fixture box.
As for how I know it, its very common. As of the NEC 2011, neutrals are required at every switch box as more and more lighting controls are requiring a neutral to operate.
Old 07-21-2012, 10:53 PM   #11
Does that dimmer really require a neutral? It sure doesn't look like it to me.
LooseSCruz is offline   Reply With Quote
Old 07-21-2012, 10:54 PM   #12
Oh sorry, I wasn't reading closely enough. Nevermind.
Old 07-21-2012, 11:45 PM   #13
The one in the last picture is the old one... the new one is at the begining of the thread...
Old 07-22-2012, 09:00 AM   #14
joed's Avatar
The dimmer in your first pictures needs a neutral. You can't use in the new box without changing the cable to the box and bringing a neutral.
Old 08-04-2012, 11:53 AM   #15
Moved to seperate thread
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 11:11 AM
double switch wiring problem avalanchehunter Electrical 5 12-13-2009 02:00 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
