Photovoltaic System Grounding Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 01:34 AM   #1
Rewards Points: 187
Hello,
I am installing a 3kW grid tie PV system on my roof. As far as I know I will need to run a solid ground conductor from the array (panels and micro inverters) to my house grounding rod.
Problem is the following:
Ground rod is located in front of house by main water line. continuous conductor runs from there all the way through the house to the back where the main service panel is located. There it connects to the main service panel's ground terminal.
The PV system (power generating wires) will tie in at the main service panel behind the house.
Option 1) run the EGC to the front of the house to the ground rod - distance too long, unpractical
Option 2) Drive new ground rod behind house, connect it to main service panel and also run solar EGC to rod - unpractical because area behind house by panel is covered with concrete and visibility of EGC is also a concern.
Another option I though of, but was not sure if possible:
Option 3) run EGC from PV system to main service panel and irreversibly splice it to incoming solid ground conductor which comes in from the ground rod in front of the house.
It looks like irreversible splices are allowed but I am not sure if this is possible in this case in this location.
AHJ still goes by NEC 2008.
Jaxx is offline   Reply With Quote
Old 03-05-2013, 07:53 PM   #2
Rewards Points: 187
Anyone, anything? :-)
Old 03-05-2013, 08:06 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Part V. of Art. 690 isn't that large, try giving it a read over.
Old 03-05-2013, 08:46 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by chikhanh418 View Post
<br />
<br />
nha thong minh , thiet bi dien thong minh , may fax , may fax panasonic hay den dvn.vn
Huh!
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-05-2013, 09:44 PM   #5
Electrical Enthusiast
Rewards Points: 504
Originally Posted by electures View Post
Huh!
Spam probably
Kyle_in_rure is offline   Reply With Quote
Old 03-05-2013, 10:45 PM   #6
Rewards Points: 187
I thought about that, but then I thought that there are probably other articles that apply to this as well. I was hoping some has had similar prior experience
Could I also get other people's opinion in the meantime?
Thanks everybody!
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 10:25 PM
Panel Grounding requirements POWER STROKE Electrical 3 08-27-2012 06:46 PM
Earth Grounding Rod Requirements wewantutopia Electrical 31 08-26-2012 07:38 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
