#1 |
Photographic light question
Hope someone can help as I'm confused....
I bought one of these: (hope links are ok) http://www.ebay.co.uk/itm/Softbox-La...#ht_4020wt_989 And have one of these inside it: http://www.ebay.co.uk/itm/1906692283...#ht_2770wt_989 The first bulb I tried didn't appear to work so I tried a replacement which worked for a split second then went off. I thought something must be wrong but I have tried a standard household bulb (60 watt screw fit) in the lamp holder and that works fine and stays on. Its plugged into a household wall socket - So what could be the problem? Many thanks, gb2012 |
#2 |
Licensed Electrical Cont.
You don't state your location, which is important. I assume the UK?
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#3 |
Yes UK
#4 |
" Euro " electrician
I am not too suprised some of the luminiare may have wattage limiter in there so if too high a wattage it will turn off I know they don't read very well with CFL loads but indentscents they work ok.
With that luminaire you posted IIRC they are good up to 100 watts. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
| Display Modes | |
| Question concerning a ceiling light and grounding | mTorbin | Electrical | 5 | 02-07-2012 09:23 AM |
| Quick Question about Ceiling Fan LIGHT KITS | watts up? | Electrical | 8 | 10-06-2011 12:04 AM |
| ceiling light question | d0ze | Electrical | 8 | 09-14-2011 10:55 PM |
| 220 Volt Electrical Wiring Question ... for light ??? | shotguns | Electrical | 11 | 05-21-2011 10:03 PM |
| Hi, new here and have a question about light switch in bathrooms | Tazznum1 | Electrical | 2 | 01-26-2011 09:31 AM |
