-   -   Photographic light question (http://www.diychatroom.com/f18/photographic-light-question-156851/)
gb2012 09-15-2012 07:33 AM
Hope someone can help as I'm confused....
I bought one of these: (hope links are ok)
http://www.ebay.co.uk/itm/Softbox-La...#ht_4020wt_989
And have one of these inside it:
http://www.ebay.co.uk/itm/1906692283...#ht_2770wt_989
The first bulb I tried didn't appear to work so I tried a replacement which worked for a split second then went off.
I thought something must be wrong but I have tried a standard household bulb (60 watt screw fit) in the lamp holder and that works fine and stays on.
Its plugged into a household wall socket - So what could be the problem?
Many thanks,
gb2012
Speedy Petey 09-15-2012 07:54 AM
You don't state your location, which is important. I assume the UK?
gb2012 09-15-2012 07:55 AM
Yes UK
frenchelectrican 09-16-2012 12:54 AM
I am not too suprised some of the luminiare may have wattage limiter in there so if too high a wattage it will turn off I know they don't read very well with CFL loads but indentscents they work ok.
With that luminaire you posted IIRC they are good up to 100 watts.
Merci,
Marc
