Photocell Usage - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2008, 03:41 PM   #1
Photocell usage
Hello,
I have a lighting fixture for my terrarium with 3 compact flourescents in it. The center bulb is on a diferent switch than the other 2. I thought it would be cool if when the 2 main bulbs went off at night (theyre on a timer) the third bulb came on with a nocturnal light in it. I was thinking of just sticking a photocell in the appropriate bulb's circuit...would this work?
Barrus is offline   Reply With Quote
Old 08-06-2008, 04:42 PM   #2
Sounds OK to me, or you could just use a second timer, and program it to turn on at night.
Photocell probably requires a neutral wire, so don't know if the switch box includes a neutral.
FW
fw2007 is offline   Reply With Quote
Old 08-06-2008, 06:36 PM   #3
Ash
Send a message via MSN to Ash
Some timers act like a 3 way switch. Yuo have a third connection labeled NC or Normally Closed to which you connect the second lamp
You may use a photo cell or a second timer too. Or use a contactor (relay) on the first circuit and connect the second thru its NC connection
But imo the best thing is to put it on a manual switch and turn it off when nobody needs it anyway. CFLs save energy but still use it
If you really want something nocturnal put there stuff that glows in the dark
Ash is offline   Reply With Quote
Old 08-06-2008, 08:41 PM   #4
Rewards Points: 508
Send a message via AIM to theatretch85
I have attached a very crude image of a relay and timer setup (sorry photoshop not working for me right now). Basically line neutral is split to timer and both lamps (bottom line wire in pic), Line hot is split to timer and relay contact common, relay NO (Normally Open - when relay de-energized) connects to lamp 1 (lamp that comes on with timer) and NC contact (Normally Closed) connects to lamp 2 (lamp that comes on after timer shuts off). Relay coil should be 120volts and powered by the timer (also could be low voltage with a plug-in ac adaptor that plugs into the timer). When the timer comes on the main light comes on, and when it shuts off, the second light comes on. Only downside with this option is if you want both lights to be off at some point (could simply put in a switch between the relay C (common) contact and line power. This would allow the timer to still do its thing, but allow you to turn the lights off at any time if you wish. Hope this makes sense.
theatretch85 is offline   Reply With Quote
Low voltage & mega kilowatt usage sdswcs Electrical 29 10-18-2013 08:22 PM
Energy usage puzzle pazure Electrical 5 11-20-2007 11:18 AM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Some 'why', not 'how', questions on stucco usage joeyboy Building & Construction 4 06-25-2007 10:22 AM
