Photocell To Turn Circuit ON During Day - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 09:58 PM   #1
Photocell to turn circuit ON during day
I know, sounds crazy for a first post. I have an outdoor security sensor that uses a solar panel to charge its batteries. Unfortunately the place it needs to be mounted is under some trees and it does not get enough light, so in the middle of the night it dies and triggers a false alarm.
I want to install a 120v landscape light next to it that will come on during the day to charge the batteries. We have confirmed that this works. Thing is, this is at my 80 y/o mother's house and I feel a timer would be too much of a hassle for her. It would need resetting after a power outage, adjusted for shorter or longer days, etc.
I have not been able to find a product suitable for outdoors that would turn on a circuit when it is light out. I'm pretty handy and thought of building something myself, but not sure how to go about it. I think if I got an outdoor junction box of some type and mounted the sensor and some type of relay in it it would work. I just know nothing about relays.
Anyone know of a product that does this, or any detailed recommendations on how to go about building it? By details, I mean links to example components that would get the job done. I did find this one product, but it is a bit pricey and I don't like the way the sensor is opposite the outlets. Also not clear how weather proof it is for long term use.
http://engravingdragon.com/PhotoelectricSwitch.html
tkcas02 is offline   Reply With Quote
Old 07-04-2013, 10:23 PM   #2
joed's Avatar
Rewards Points: 11,990
If you check the specs on some these units you find some with both NC and NO contacts.
http://www.automationdirect.com/adc/...251E_Models%29
Old 07-05-2013, 01:44 AM   #3
" Euro " electrician
frenchelectrican's Avatar
If you go with the twistlock photocell and order a reversed operation aka tunnel photocell which it means the photosensor will turn the load on during day time then turn it off when it get dark.
There is one model it do come in my mind is Fisher Pierce FP7760-RA
That model number mention reversed action so it will run " backward " of normal photocells.
I really doubt the big box store will ever stock this item but check one of the electrical supply centre and mention that catalog number and they will able find it for ya.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
HARRY304E (07-05-2013)
Old 07-05-2013, 01:50 AM   #4
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Merci,
Marc
HA HA! Well I did not know that myself
Good man Marc....
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
The Following User Says Thank You to HARRY304E For This Useful Post:
frenchelectrican (07-05-2013)
Old 07-05-2013, 01:55 AM   #5
Good man Marc....
Now you know and learn something new all the time.
Merci,
Marc
Old 07-05-2013, 08:32 AM   #6
Rewards Points: 344
You would have to put it inside, but this timer has a battery backup and it adjusts for length of day:
http://www.amazon.com/Intermatic-DT6...termatic+timer
Can be set to come on at dawn and off at dusk.
herdfan is offline   Reply With Quote
Old 07-05-2013, 09:07 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Why not have the light come on at night and keep the batteries charged? It will also act as a security light
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Msradell (07-05-2013)
lights won't turn on, circuit breaker is fine. danio Electrical 3 09-21-2012 06:37 PM
Did My GFCI Circuit Breaker Fail? Jazan Electrical 8 08-04-2012 04:44 PM
Lost Neutral on K&T Circuit RST Electrical 4 11-29-2011 12:25 PM
Circuit for bathroom in the basement felipe_heidrich Electrical 4 08-26-2011 05:54 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
