Old 07-12-2012, 02:14 PM   #1
Photo Electric Switch
I'm trying to have an outdoor fountain automatically turn off when it gets dark out and back on at daylight. This is directly opposite of how my photoelectric(PE) switch operates my flagpole light. So... How do I get the typical PE switch to work in reverse?
MNova is offline   Reply With Quote
Old 07-12-2012, 03:17 PM   #2
MarginallyQualified
Originally Posted by MNova View Post
So... How do I get the typical PE (NC) switch to work in reverse?
I don't think you can.
You'll need a different switch...
either double throw or NO (vs standard NC).
TarheelTerp is online now   Reply With Quote
Old 07-12-2012, 04:10 PM   #3
Master Electrician
I'm sure they probably make a low voltage inverter for signal wires but its probably ten times more expensive than a new cell. You could use a relay and wire it to the normally closed contact so when the cell goes off the relay opens the contact.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
Evstarr (07-12-2012)
Old 07-12-2012, 05:38 PM   #4
Semi-Pro Electro-Geek
I'd use a relay with normally closed contacts.
mpoulton is offline   Reply With Quote
Old 07-12-2012, 07:34 PM   #5
E2 Electrician
stickboy1375's Avatar
Use a relay, oh wait, that was suggested... I'd still use a relay.
Old 07-12-2012, 08:16 PM   #6
It was a dark and stormy
Yoyizit's Avatar
Hosfelt has suitable relays with 120v coils for cheap. The relay contacts have to be suitable for your load so post your fountain pump specs.
How to rewire outlet controlled by light switch? BuckyGunts Electrical 30 04-20-2012 03:18 PM
Electric Time Switch David Cosner Electrical 2 03-30-2011 12:15 PM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 01:11 PM
Push Button Switch for Electric Motor crmays Electrical 2 02-06-2010 07:29 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
