-   -   Photo Electric Switch (http://www.diychatroom.com/f18/photo-electric-switch-150041/)
MNova 07-12-2012 01:14 PM
I'm trying to have an outdoor fountain automatically turn off when it gets dark out and back on at daylight. This is directly opposite of how my photoelectric(PE) switch operates my flagpole light. So... How do I get the typical PE switch to work in reverse?
TarheelTerp 07-12-2012 02:17 PM
Originally Posted by MNova (Post 964100)
So... How do I get the typical PE (NC) switch to work in reverse?
I don't think you can.
You'll need a different switch...
either double throw or NO (vs standard NC).
andrew79 07-12-2012 03:10 PM
I'm sure they probably make a low voltage inverter for signal wires but its probably ten times more expensive than a new cell. You could use a relay and wire it to the normally closed contact so when the cell goes off the relay opens the contact.
mpoulton 07-12-2012 04:38 PM
I'd use a relay with normally closed contacts.
stickboy1375 07-12-2012 06:34 PM
12 Attachment(s)
Use a relay, oh wait, that was suggested... I'd still use a relay. :)
Yoyizit 07-12-2012 07:16 PM
Hosfelt has suitable relays with 120v coils for cheap. The relay contacts have to be suitable for your load so post your fountain pump specs.
