Photo-cell Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 04:39 PM   #1
Question
Photo-cell not working
I installed a dusk to dawn photo sensor on a 300 watt quartz light and it will not come on when I cover the photo cell. The Photo cell is made by Intermatic Corp, modle k4221x, 120V 1800 watts,8.3amp ballast. I read 124v from the feed side and 0v on the red wire load side. What did I do wrong?
Signed; Stormman Norman
moonjacks is offline   Reply With Quote
Old 07-24-2010, 04:41 PM   #2
Electrician
Proby's Avatar
Originally Posted by moonjacks View Post
I installed a dusk to dawn photo sensor on a 3000 watt quartz light and it will not come on when I cover the photo cell. The Photo cell is made by Intermatic Corp, modle k4221x, 120V 1800 watts,8.3amp ballast. I read 124v from the feed side and 0v on the red wire load side. What did I do wrong?
One possibility is that your photocell (1,800w) is way undersized for the light (3,000w).
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
moonjacks (07-24-2010)
Old 07-24-2010, 04:56 PM   #3
Photo cell
Hi,I put many (0's) it shoud read 300watts, sorry about that.
Norm
Old 07-24-2010, 05:02 PM   #4
Electrician
Proby's Avatar
Are you sure you have it wired correctly?
Have you tried using it at night? Sometimes just covering the photocell isn't enough, light could still get in. Cover the eye and surrounding area with many layers of black tape and leave it, some photocells take a few minutes to switch on.
Old 07-24-2010, 05:08 PM   #5
I tried covering it with electrical tape waited 15 mins and still no lite. I thinking it's the 300watt qurtz lite, but the photo cell is rated at 1800 watts.
Thank you,
StormanNorman
Old 07-24-2010, 06:02 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
black is the incoming hot wire. Red goes to the load. White is tied in with the neutral from the circuit feeding the light.
so, you have that right, right?
then once you hook it up, take the box the thing came in and put it over the sensor and tape the box where it is open around the sensor. Give it 5+ minutes. It should turn on.
btw: if you can watch the light as you are first energizing the circuit, it will turn on for a moment or so until it can react to the light (if the box isn't on the sensor). If it doesn't, you might have a bad sensor. Very unusual in my experience but not impossible.
Old 07-24-2010, 06:07 PM   #7
Electrical Contractor
kbsparky's Avatar
What color electrical tape did you use? Only black tape can fool an eye into thinking it's dark outside ....
-KB
Old 07-24-2010, 06:11 PM   #8
nap
You talking to me?
nap's Avatar
true dat
Old 07-24-2010, 07:11 PM   #9
Hi,
Yes I had the black feed side to the black photo cell wire and the red wire to the lamp load ,covered the senor with black electrical tape for 15 mins and still no light or power to the red wirw reads 0v's.
Thanks anyway;
StormanNorman
Old 07-24-2010, 07:13 PM   #10
Hi,
Yes i did, just one of the things no one can explain.
Thanks anyway
Old 07-24-2010, 07:16 PM   #11
nap
You talking to me?
nap's Avatar
Hi,
Thanks anyway;
StormanNorman
and the neutral?
did this light work before installing the photocell?
Old 07-24-2010, 09:22 PM   #12
and the neutral?
yes the light worked and neutral is ok.
Old 07-24-2010, 09:43 PM   #13
nap
You talking to me?
nap's Avatar
and the neutral on the pc is connected to the circuit neutral. (that is what I was trying to get you to acknowledge)
the only thing left is a bad PC.
Old 07-24-2010, 10:33 PM   #14
Yes the neutral is connected to the circuit neutral.
I think it has somthing to do with the quartz lite but not sure.
Anyway thank you much for trying to help.
signed StormanNornan
Old 07-24-2010, 10:50 PM   #15
nap
You talking to me?
nap's Avatar
a quartz light is basically a fancy incandescent lamp. It still produces light by the current flowing through the element causing it to heat up and incandesce.
what the difference between a typical incandescent light and a quartz light is with the typical incandescent lamp, it uses a low grade glass and uses either a vacuum or nitrogen, argon, or krypton gas. Both types use a tungsten filament.
the quartz lamp uses halogen as the gas and the envelope is quartz, which can withstand very high temps. The type of gas actually allows the vaporized tungsten to reattach to the filament where with a standard incandescent lamp, it attaches to the envelope eventually allowing the filament to thin an break.
the are both incandescent lamps though.
it isn't the lamp causing your problems.
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
Pern value of 8 inches of open cell foam millertimeny Building & Construction 0 03-23-2010 12:28 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
photo cell lights thst only work sometimes... kemerick Electrical 10 11-10-2007 12:29 PM
