Phone Wire Along Side Of Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 07:41 AM   #1
Rewards Points: 141
Phone wire along side of electrical wiring
Quick easy question, just wanting to make sure: Is it okay to run my telephone wire right along my electrical wiring on it's way up to phone jacks? May sound like a strange question, but I just want to make sure that immediate proximity to electrical wire does not mess with good phone cable operation and reception.
Thanks!
DiegoJames is offline   Reply With Quote
Old 07-10-2012, 05:53 PM   #2
The analysis is pretty messy, so try it.
Run 10A or 20A through some Romex and have the cable paralleled with your phone wire over a few feet. Listen for a 60 Hz hum in the phone. It's the magnetic field, not the electric field, that you're worried about, so tin foil shielding should not help here.
If there is a hum try phone wire that uses a twisted pair. And maybe somebody makes twisted pair Romex.
Old 07-10-2012, 05:54 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks!
You have a hard wired phone? sorry... couldn't resist... If the wire you are running is twisted, I wouldn't lose much sleep over how close they are.
Old 07-10-2012, 05:55 PM   #4
E2 Electrician
LOL, you crack me up.
Old 07-10-2012, 06:01 PM   #5
Master Electrician
actually a shield should help alot, that's what it's there for. You float one end of it and tie the other end into the ground to "drain" and induced current. We do it for fire alarm and AV systems all the time.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-10-2012, 06:10 PM   #6
If I can't be right at least I can be funny.
Then it's an E-field shield. IIRC, a mag shield (H-field) needs to be of ferrous metal. If I haven't given my fields book to the Salvation Army I'll check on this.
Old 07-10-2012, 06:18 PM   #7
Rewards Points: 141
hard wired phone
Well stickboy, actually I DON'T have a hard wired phone! I'm strictly mobile. But I'm at least getting cat5 in the whole house as I renovate so that it has it for the next owner! (if they want it)
Old 07-10-2012, 06:21 PM   #8
E2 Electrician
as a rule of thumb in my own little world, I try and maintain a 3" separation, or keep the low voltage to the other side of the joist, but I don't hesitate to run them parallel either.
Hot Tub Wiring Question - Wire Type? AidanD55 Electrical 10 03-18-2012 01:16 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
phone wiring Potomac101 Electrical 8 02-11-2008 04:23 PM
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 09:05 PM
