Old 06-24-2008, 08:05 AM   #1
Phone will not hang up--help!
I just ran a phone line from the network interface box (through the attic, through a closet, through a wall) to install a phone jack. I have a DSL and a telephone to run off of that jack. When I plug both in, via a splitter (and the phone is connected to a DSL filter) the phone works 1 time (dial tone and ability to call) but I cannot hang up the phone at all. Even if I hang up and then pick back up 1 minute later, it is as if it did not hang up at all. If I plug the phone directly into the jack without anything else plugged in, it will hang up.
Any ideas?
rudy6380 is offline   Reply With Quote
Old 06-26-2008, 02:10 PM   #2
what kind of wire you used?
ehoez is offline   Reply With Quote
Old 06-29-2008, 09:25 PM   #3
Your basic telephone takes only two wire to operate on. That is refered to as the TIP and RING. At you juction box you should have two wire for your phone line. Most of the time it will be black and red. Check this 1st and use a telephone and connect these two wire and insure you have service at the box, and it is working correctly. If yes make sure the wires are good into the house and to your final location watch that in securing the cable no wires are cut into or shorted by the staples you are using to secure them as you install the new wire. Make sure you have the tip and ring at the final terminating point. There should not be any change in the final connection, unless you have shorted a wire.
charlie C is offline   Reply With Quote
phone problems AStott Electrical 13 06-07-2008 07:27 PM
Mutiple phone line needs an answering machine Densplace Electrical 5 04-04-2008 11:35 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-18-2007 12:46 AM
