Phone Junction Box Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 01:58 PM   #1
I want phone service installed in my new home. According to the phone company, I am required to provide a ground at the phone junction box. NEC 800.100 supports this assertion.
Unfortunately, it would be very difficult to run wire from the location of the phone junction box to the service entrance panel. However, I can easily install wire from the location of the phone junction box to the crawlspace under my house. I could attach directly to the grounding electrode conductor, which is readily accessible in the crawlspace. My question is:
Does the NEC allow me to connect an equipment grounding conductor directly to the GEC, or must all equipment grounding conductors run back to the service entrance panel and bond at that location?
kflynn is offline   Reply With Quote
Old 02-17-2010, 03:23 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... Is there atleast a square Inch or two of soil around the new Phone J-box,..??
If so,... Buy a ground rod,+ drive it home,... Perfect ground, Where needed...
You're attemping to estabish Ground for the phone system, not the electrical system...
No need to concern yourself with the Main Entrance...
Bondo is online now   Reply With Quote
Old 02-17-2010, 06:32 PM   #3
joed's Avatar
Rewards Points: 12,008
Absolutely the wrong info.
The phone ground (and cable and satellite) must be all be tied to the main electrical grounding system.
Are you referring the ground cable from the panel to the ground rods? If so you may connect to the nearest accessible location of the ground system.
Old 02-17-2010, 07:45 PM   #4
Rewards Points: 6,652
Since my NID sits right under the Meter Pan, we just ran some #8 to the ground rod, since only the NID & CATV are right there. Inside, I would still install a whole house Surge Protector, that also incorporates CATV & Telco into it for that extra step.
Old 10-27-2010, 08:53 AM   #5
Second Idea
The phone company needs a ground at the junction. Put the first junction right by the electrical pane and from their, its all fun and games.
kwoznia1 is offline   Reply With Quote
Old 10-27-2010, 09:13 AM   #6
Rewards Points: 150
I thought it was the Phone Company's responsibility to install a ground and bond their service during install? That is the way I have always seen it in both NJ and IL.
TJ_in_IL is offline   Reply With Quote
Old 10-27-2010, 01:46 PM   #7
Rewards Points: 324
not legal to put phone ground inside your breaker panel period.you can attach to cold water pipe or a ground rod.the phone guy's need access to where you connect it.if you have to install it it needs to be a #10 solid wire.leave plenty of slack so phone co. can connect to de-mark.
oleguy74 is offline   Reply With Quote
Tags
gec , grounding conductor , junction , phone
conduit coming out of the ground, or exiting building near the ground wmldwilly Electrical 10 05-24-2009 05:44 AM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
Temporary Genrator Ground theatretch85 Electrical 32 08-05-2008 01:05 PM
Panel ground questions Joe F Electrical 12 08-05-2008 10:48 AM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-18-2007 12:46 AM
