Phone Jacks Not Working Upstairs, All Good Downstairs. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 11:19 AM   #1
Phone jacks not working upstairs, all good downstairs.
I've done some searching for answer but couldn't find anything related directly to my question.
About a week ago, the phones upstairs suddenly stopped working. I've tried all(3) jacks, i've tried unplugging all the phones and then plugging them back in(was told to do this by the telephone company that it should reset the system). We do have an alarm system running through the phone jack in the master bedroom, however that was installed several years ago.
All jacks downstairs are working OK.
I do not have a volt meter so i haven't tested for voltage yet, however I'm getting one either today or tomorrow, depends on how work goes.
Any other ideas on what could have happened?
rmsmith1977 is offline   Reply With Quote
Old 12-12-2010, 11:35 AM   #2
Sounds like a failed connection at one of the jacks, or a break in the wiring (critter chewed it, perhaps?).
clashley is offline   Reply With Quote
Old 12-12-2010, 11:48 AM   #3
Licensed electrician
Rewards Points: 1,622
Older phone wiring was run from A to B to C etc. You need to check the connections behind the plate.
Old 12-12-2010, 10:40 PM   #4
I'll check both, thanks
Old 12-13-2010, 07:37 AM   #5
Rewards Points: 36
As Jim said look for bad connections behind the other jacks.You won't need a volt meter just use a known good phone and check for dial tone.
daveb1 is offline   Reply With Quote
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Mutiple phone line needs an answering machine Densplace Electrical 5 04-04-2008 10:35 PM
installing more phone jacks JAVAMAN General DIY Discussions 6 11-27-2007 08:37 AM
couple questions about installing phone jacks joeyboy Electrical 31 10-09-2007 02:26 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-17-2007 11:46 PM
