Philp T8 Light Bulb Is Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 11:11 AM   #1
philp t8 light bulb is not working
Why my newly purchaser light blulb is not working. I bought exact 32 watts 48 inch F32 T8. I know my fixture is ok since the previous lights went out gradually. At list that is what I like to believe. Any help?
sawu is offline   Reply With Quote
Old 10-24-2012, 11:19 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Do you have a t8 ballast in the fixture?
The Following User Says Thank You to jbfan For This Useful Post:
jrclen (10-24-2012)
Old 10-24-2012, 12:46 PM   #3
joed's Avatar
Rewards Points: 12,446
Standard Fluorescent fixture repair after first verifying power is present.
1. Replace the tubes.
2. If #1 doesn't fix it replace the ballast.
Old 10-24-2012, 05:35 PM   #4
Rewards Points: 266
What joed says generally. In this case, since I don't know your electrical and mechanical competency, I suggest that you could have damaged the sockets when changing the lamp. Did you have any trouble when removing or installing the lamps? Is it an old luminaire?
ionized is offline   Reply With Quote
Old 10-24-2012, 08:07 PM   #5
kbsparky's Avatar
Originally Posted by sawu View Post
... I know my fixture is ok since the previous lights went out gradually....
Not a valid reason to assume that the ballast is working properly.
Sometimes, you can get bad bulbs. Try them in another working fixture to verify the bulbs are OK.
But the next step is replace the ballast if the bulbs are verified to be good.
-KB
Light switches and outlets stopped working. jeweladdict Electrical 4 08-13-2012 10:51 AM
Ceiling fan light kit - light not working tfdelaney Electrical 4 12-06-2011 09:28 AM
After replacing a light fixture the fan is not working but the lights do aniamaja Electrical 9 07-14-2011 08:23 AM
Outdoor post light - random blinking bulb handymike Electrical 9 06-14-2010 01:29 PM
Light & switch not working jgayle Electrical 1 01-18-2009 05:28 PM
