Phase Out. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 02:30 PM   #1
Phase out.
Why would a phase go out on a three phase electrical panel?
javierss507 is offline   Reply With Quote
Old 05-24-2011, 03:15 PM   #2
Licensed electrician
Rewards Points: 1,634
Could be a utility company problem or a problem in the facilities panel.
Old 05-24-2011, 03:34 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,372
If its not a faulty switch / fuse or a loose connection,
Then it could be a blown fuse only on one phase,
Possibly the phases are not balanced and there
is too much om one phase.
There will be a fuse for each of the three phases.
call poco !
dmxtothemax is online now   Reply With Quote
Three phase transformer question rongaudier Electrical 8 03-08-2011 07:19 AM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 09:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
