Old 01-30-2011, 03:39 AM   #1
Phase converter question
Hello,
I'm installing a 7.5 hp phase converter (single to three phase) for a 3 phase drill press and dust collector in my workshop. It looks like I need to run 8-3 from the converter into the panel, with L1 and L2 connected to a 40 amp, 2 pole breaker, and L1 and L2 (10-3 or 12-3) into the panel from the loads, also to separate breakers. L3 from the converter and the loads are supposed to be spliced with a split-bolt connector. The question is - can I splice the L3 wires inside the panel with the split bolt? Or does it need to be done in a separate box? Thanks - I appreciate any help.
lfparker is offline   Reply With Quote
Old 01-30-2011, 07:50 AM   #2
Master Electrician
Is this a rotary converter or a static one?
brric is offline   Reply With Quote
Old 01-30-2011, 08:42 AM   #3
It's a rotary phase converter.
1 & 3 phase questions 527ink Electrical 10 01-05-2009 01:13 AM
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
3 phase power phase question jelliott Electrical 16 12-20-2008 04:21 PM
hrv question indep HVAC 3 07-17-2008 11:39 PM
3 phase panel question curse21 Electrical 2 08-18-2004 11:17 PM
