#1 |
phase converter
My son loves making sawdust and is always looking for good buys on tools. He scours Craigslist, etc and finds incredible prices on used stationary tools that are 3 phase. For instance, he found a 52" double belt sander for $3000, when a 16" open ended single phase is around the same price. Well, he doesn't have 3 phase in his garage and keeps talking about getting a phase converter. I know nothing about them other than they cost a bunch.
http://www.phase-a-matic.com/PDF/RPL.pdf Question is: should that be an option for him to explore? or should he just keep looking for a score on single phase equipment? Last edited by n175h; 12-10-2012 at 10:02 PM. |
#2 |
phase converter
It depends. Does he have a large enough service to support these rather large tools? Phase adders work well, but not often used in other than industrial applications.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
phase converter |
#4 |
phase converter
A sander that size can be up to 25hp. The service may not be able to handle the startup surge.
#5 |
Semi-Pro Electro-Geek
phase converter
What are the power requirements of the sander? If it's 5HP or less, then a VFD with single phase input is probably best. That is still an option for 5-15HP or so, but it gets much harder. Rotary phase converters are functionally acceptable, but inefficient, huge, and annoying. You can make a rotary converter much cheaper than you can buy one. All you need is a large 3-phase motor, some capacitors and contactors, and optionally a small single phase motor to start up the big motor.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice. |
#6 |
JOATMON
phase converter
As Mpoulton said....VFD.....
Or....replace the 3 ph motor with a single phase 240Vac motor.....in some cases, the motor will be cheaper than the VFD. However, if you have more than one 3ph tool....the VFD is cheaper.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
phase converter |
#8 |
phase converter
Let him speak for himself.
#9 |
phase converter
25HP is doable with a rotary converter, which you could build fairly easily with a 30HP 3-phase motor.
| Display Modes | |
| hELP! Amperage needed for 220V motors | 1488rob | Electrical | 22 | 03-18-2011 04:28 PM |
| Three phase transformer question | rongaudier | Electrical | 8 | 03-08-2011 08:19 AM |
| Phase converter question | lfparker | Electrical | 2 | 01-30-2011 08:42 AM |
| Want to add a single phase Subpanel to three Phase Main | meglomachinist | Electrical | 19 | 09-10-2009 04:46 PM |
| 3 Phase Converter Wiring | ideffects | Electrical | 22 | 05-26-2008 09:05 PM |
