Phantom Voltage? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 07:04 PM   #1
Phantom voltage?
I replaced a light bulb on one of my switched outlets with an LED and noticed the bulb was dimly lit when the switch was off. I used my DMM and it shows 60 volts when off and 120 when on. My builder said it's not an issue as it's phantom voltage and that everything is okay. Do you guys agree with that?
I checked another switched outlet in my house and it had the same thing (60 volts and the LED bulb would come on dimly lit).
Thanks for your time and assistance.
mashean is offline   Reply With Quote
Old 06-08-2012, 07:07 PM   #2
Almost certainly this is not a phantom voltage.
Old 06-08-2012, 07:15 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I agree... an issue exist somewhere. Open or loose neutral connection would be a good guess.
Old 06-08-2012, 07:30 PM   #4
Rewards Points: 3,256
What kind of switch do you have? Old style no frills off/on or a modern lighted or motion switch.
zappa is offline   Reply With Quote
Old 06-08-2012, 07:40 PM   #5
Zappa, one is a standard on/off switch and the second is a dimmer switch. The house is 2 years old
Old 06-08-2012, 07:49 PM   #6
I would expect it to stay partially lit on the dimmer circuit. I know it's crazy but the LED's don't take much to make them glow. Do they immediately go out if you unscrew it?
Old 06-08-2012, 07:56 PM   #7
E2 Electrician
So where is the 60v coming from? That is the question.
Old 06-08-2012, 08:06 PM   #8
Rewards Points: 776
Well you might be able to come up with a leakage current theory for the dimmer such as it isn't fully off as in the slider won't go to zero), or the triac inside is damaged and leaking current when off, or it is a smart switch that draws a trickle of power to run its internal electronics.
The fact this also happening for the mechanical switch is saying something very strange. There is no phantom voltage leakage current theory if the current is physically open circuit. Are you sure there isn't a 3 way in the switch path and it is some type of electronic switch paired up with the mechanical switch?
curiousB is offline   Reply With Quote
Old 06-08-2012, 08:17 PM   #9
You could substitute a non-electronic household toaster for the bulb and measure the voltage again. And measure the resistance of your toaster - it should be about 10 ohms.
Old 06-08-2012, 08:32 PM   #10
Edit out.
Old 06-08-2012, 08:37 PM   #11
Rewards Points: 1,418
THe ordinary switch (or at least one of a pair of 3-ways) does not have a night light inside it does it? That could cause a low wattage light such as an LED lamp to come on.
Old 06-08-2012, 10:10 PM   #12
Thanks for your thoughts. The mechanical switch is just an on/off switch without a light of any sort. The dimmer also has a switch but also the sliding dimmer part where I can adjust. The switch does turn it off completely and there aren't any lights on it either. I've placed a couple books on hold at the library regarding electrical so I'll read through them to get a better understanding of how things should work and how to verify they're as they should be. Odd my builders electrician says its normal.
Old 06-08-2012, 10:20 PM   #13
E2 Electrician
The funny thing is how he calls it phantom voltage yet the light is dim... well I guess its not really phantom now is it? Im still going with open neutral... but time will tell on this one.
Old 06-09-2012, 10:14 AM   #14
Just a guess but it could be an ungrounded RFI filter in a TV, microwave or computer dividing the 120v by two and putting it on the neutral.
Resistor/Led and Basic Electricity Questions Khivar Electrical 19 04-16-2012 07:15 PM
Phantom voltage rrunkle Electrical 15 02-08-2012 09:23 AM
Voltage Detector Affected by Snow? Arnold Ziffel Electrical 1 02-01-2012 10:56 PM
Phantom voltage -- I'm completely stumped kb01 Electrical 2 12-24-2010 07:44 PM
Phantom voltage reading on switch loops jamiedolan Electrical 5 02-09-2009 05:22 PM
