Old 09-26-2008, 03:31 PM   #1
Question
Is a Permit required for additional light ?
[FONT='Arial','sans-serif']I'm planning to add a second light fitting to the existing one in my garage. I intend to connect this new second unit to the original one in parallel using 14 g Romex cable run in the attic.[/FONT]
[FONT='Arial','sans-serif']I'm new to Eletrical installations like this but have fitted fans and light fittings so feel confident to do this work. [/FONT]
[FONT='Arial','sans-serif']Will I need a Permit ? and where do I obtain one ?[/FONT]
[FONT='Arial','sans-serif']Thanks,[/FONT]
[FONT='Arial','sans-serif']Dave[/FONT]
Handy Dave is offline   Reply With Quote
Old 09-26-2008, 03:33 PM   #2
RippySkippy's Avatar
I'm sure others will chime in shortly...but that type of thing in my area wouldn't. To be certain you could/should contact your local permitting office.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 09-26-2008, 03:38 PM   #3
www.handyguyspodcast.com
It can't hurt to ask your local inspector. When I was adding a small sub panel to my attached garage for a workshop I filled out the permit information and the inspector returned it. He said the materials for the job were not enough to warrant a permit. I didn't need one. He did suggest I have an underwriter (independent inspector) check out the work and put a tag on the panel to certify that it was inspected.
borninpa is offline   Reply With Quote
Old 09-26-2008, 04:59 PM   #4
Moderator
Termite's Avatar
Yes, in any jurisdiction under the International Code, you'd need a permit.
Per the IRC Section R105/Electrical:
Permits are required to:
....erect, install, enlarge, alter, repair, remove, convert, or replace any electrical...
It sounds silly to some, but many many many people do not correctly install light fixtures. Heck, many electricians don't correctly install them on a very regular basis!
The best thing to do is ask the local inspector. He/she will let you know if they want you to pull a permit.
I can't belive the negligence of the inspector in borninpa's area...A subpanel should always be inspected...There's just too much that can be done wrong and dangerously.
Old 09-26-2008, 08:39 PM   #5
The scary thing is what ive found several years after an INSPECTED remodel was complete on my house.
exposed junction boxes, 14 awg on 20 ampere circuit....wrong connectors...40 amp breaker with 10 awg wire...etc.
rgsgww is offline   Reply With Quote
Old 09-26-2008, 10:41 PM   #6
Moderator
Termite's Avatar
There are hacks in every trade, and there are certainly worthless inspectors just like there are worthless electricians.
But honestly, the inspector shares the responsibility with the lousy contractor that you hired.
Also, junction boxes are required to be exposed/accessible.
Old 09-27-2008, 12:19 AM   #7
. Also, junction boxes are required to be exposed/accessible.
I know that, what I ment was that the box diddn't have a cover.
The electricians were from metro electric (if you ever heard of them) and thompson electric (I think they are local to my area though) Anyways, they are all union I think. Ive fixed the major problems, Now I have to deal with voltage drop in 2 rooms, looks like an easy fix for the worst room, when a 12 amp load is pulled, the voltage drops from 123 to 110.
Old 09-27-2008, 12:21 AM   #8
Check with your city, they will decide what must be inspected and what doesn't. If it doesn't you still have to do it right of course.
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
length/width deere2440 Building & Construction 17 03-01-2008 10:45 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
