Permanently Bypass Motion Sensor Light - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 03:28 PM   #1
I have a motion sensor in my garage for a multi-switch light. I want to permanently bypass the motion sensor. The motion sensor is a Zenith SL-5403. It has a black, red, and white wire connected into the wiring for the lights. The black wire becomes energized when the light switch is turned on. While the motion sensor is active, the red wire is energized. I believe the white wire is a neutral. Can I just disconnect the wiring of the motion sensor and connect the wires from where the black and red wires were connected to each other?
pwlear is offline   Reply With Quote
Old 05-22-2011, 04:27 PM   #2
Lic Elect/Inspector/CPO
The black is power in from switch, when motio is detected the power goes to red which is connected to the lights.
You can cut the red and cap it. Than feed the light wires directly to the black wire. When switch is turned on the lights will come on.
NJMarine is offline   Reply With Quote
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 09:52 AM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 11:16 AM
bypass motion sensing switch rickdog Electrical 5 04-01-2010 11:06 PM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
