Perfectemp Pool Heat Pump Stopped Defrosting - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 11:26 AM   #1
Perfectemp pool heat pump stopped defrosting
I have a 5 year old Perfectemp heat pump for my outside pool and it has decided to stop defrosting itself.
Does anyone know if this is a common problem and/or how I fix it?
Jap65 is offline   Reply With Quote
Old 06-10-2012, 04:46 PM   #2
Rewards Points: 1,442
You would need to find out what accomplishes the defrosting. Common reasons for defrost failure include:
1. A heating element for that purpose has burned out.
2. A mechanical timer used to switch the heating element on and off (say once for one hour every 12 hours) has stopped running.
A schematic diagram, either in the manual or on the inside of a panel of the unit, would show the defrost mechanism and/or components.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
Jap65 (06-12-2012)
Old 06-10-2012, 05:15 PM   #3
Rewards Points: 3,256
One of 2 things....your clixon thermostat on the condensor coil or the electronic control board. It could also be the reversing valve but that would be my last pick.
You may want to pose this question in the HVAC forum as well.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
Jap65 (06-12-2012)
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Carrier Heat Pump stopped working burnselk HVAC 2 02-06-2010 01:30 AM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
