Old 06-07-2009, 11:25 AM   #1
It was a dark and stormy
Yoyizit's Avatar
Per kilowatt-hour
does anyone in North America pay more than 16 cents or less then 4 cents?
Thanks in advance.
Old 06-07-2009, 11:48 AM   #2
Idiot Emeritus
Per kilowatt-hour
Around here, the base rate is about 13 cents. After I pay for the bums and welfare moms to have free power, subsidies for green power, and several other equally idiotic charges, it's a shade over 14 cents.
The CEO of the power co. makes over $3,000,000 a year. I wonder just exactly how much of my money goes to support his lavish lifestyle.
Rob
micromind is offline   Reply With Quote
Old 06-07-2009, 01:10 PM   #3
Per kilowatt-hour
10.5 here (residential)
Small business is around .18 IIRC.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 06-07-2009, 01:26 PM   #4
Per kilowatt-hour
16.89 without the $2.20 per month customer charge, 17.19 with.
surrogate is offline   Reply With Quote
Old 06-07-2009, 02:00 PM   #5
Per kilowatt-hour
$0.0908 plus $11.00 customer charge and a rider adj. of -3.14
hayewe farm is offline   Reply With Quote
Old 06-07-2009, 07:47 PM   #6
Yoyizit's Avatar
Per kilowatt-hour
Thanks, folks; I come in at about 16 cents/kwh, so I'm not getting totally gouged.
Anyone out there from the Tennessee Valley?
Old 06-07-2009, 07:53 PM   #7
Kap
Mowing my life away.
Per kilowatt-hour
We pay 40-50 cents per kwh here depending on fuel costs.
Right now now we're right arond 42 cents.
Kap is offline   Reply With Quote
Old 06-07-2009, 09:02 PM   #8
Xtreme DIY'r
Per kilowatt-hour
Last months bill was 11.65 cents per kwh
That is supposed to drop to 9.734 cents per kwh next month
So a drop of about 2 cents per kwh
Ou rbill should drop close to $30 a month, maybe more
With all the delivery charges it equals out to 16.7 cents per kwh right now. Delivery charges are about 1/3 of the bill
Old 06-07-2009, 09:26 PM   #9
Per kilowatt-hour
Originally Posted by Yoyizit View Post
[does anyone in North America pay more than 16 cents or less then 4 cents?]
Thanks in advance.
The highest number on the scale i.e. 16c. per KWH. is not the NET charge that you pay to the Utility! There are miscellaneous fixed and variable charges that are added to the bill. Taxes, Fuel costs and "Delivery" charges are some of the items that are tagged on to the bill. The way I figure my NET charge per KWH is that the amount on the bill is divided by the KWH used!!!
spark plug is offline   Reply With Quote
Old 06-08-2009, 09:03 AM   #10
Yoyizit's Avatar
Per kilowatt-hour
That's what I do. It's the "marginal" rate. $~64/390kwh = ~16 cents for April.
There's a short novel, which I ignore, on each bill talking about where all the money goes.
Old 06-08-2009, 11:43 AM   #11
DIY'r
ScottR's Avatar
Per kilowatt-hour
$0.0857 peak
$0.0787 off peak
Plus a per-KWH supply charge of $0.1050 = $0.1907
With all the other nonsense I get $0.1973 as the bottom-line net charge, averaging between actual readings. (Of course that's a mix of peak and off-peak).
ScottR is offline   Reply With Quote
Old 06-08-2009, 12:41 PM   #12
Yoyizit's Avatar
Per kilowatt-hour
100% pay between 9 and 42
75% pay between 11 and 20
50% pay between 17 and 14
Maybe I'm getting gouged on NG rates; that will be my next question.
any opinions on Amanna Goodman One Hour heat and Air? grgryl HVAC 1 08-25-2008 11:33 PM
Low voltage & mega kilowatt usage sdswcs Electrical 23 02-03-2008 02:51 PM
48 hour acclimation for laminate CD08 Flooring 3 11-06-2007 07:34 PM
