Pendent Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 09:43 PM   #1
Question
pendent lights
I would like to add two or three pendent lights in my kitchen over my island. Can I tie them in to the run of other lights or do I need to start from scratch at the electrical panel?
Blond is offline   Reply With Quote
Old 09-08-2012, 10:00 PM   #2
Licensed electrician
Rewards Points: 1,766
If there is reserve capacity on the circuit you can add new lighting to it.
Old 09-08-2012, 11:11 PM   #3
" Euro " electrician
frenchelectrican's Avatar
If this circuit is not heavy loaded then you can do that and you can start at the switch box as long you have good power source there ( hot et netural ) and have plenty room in the switch box otherwise you will have to add a extra gang on the switch box.
If you want the pendents luminarie to be tied the main luminaires you can do that as well so you have either way to do this.
Merci,
Marc
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Lights still dimming and flickerin Keisha34 Electrical 18 06-08-2012 11:14 PM
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 02:22 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
