Pendant Lamp Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 11:53 PM   #1
Pendant lamp not working
looking for some help, this forum seemed to provide good solutions
I installed a pendant lamp to the ceiling but it wouldn't turn on
I used a multimeter to make sure the terminal was live, check.
did a continuity test by connecting the white and black wires on the lamp and then touching the multimeter probes to the shell and contact on the socket and it showed a closed circuit.
Put everyhing back together and the deng light still doesn't turn on
Am I missing something?
thanks
adogg is offline   Reply With Quote
Old 11-30-2011, 06:17 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
How is it wired?
Explain from the switch to the fixure.
Old 11-30-2011, 09:40 AM   #3
The ceiling junction box is wired to a switch/dimmer on the wall, that is all the transparency I have on that. In the junction box is a black and white wire, with a ground wire screwed to the j-box. I tested the wires and it is getting full voltage when I turn the switch on.
Old 11-30-2011, 09:42 AM   #4
I connected the ground wire from the fixture to j-box, white to white, and black to black.
Old 11-30-2011, 10:06 AM   #5
Is the bulb blown? Is there by chance a cfl in the fixture and the dimmer doesn't support cfls? If you screw out the bulb, is there power in the socket?
jfrotten is offline   Reply With Quote
Old 11-30-2011, 04:51 PM   #6
I was using a CFL, went home and tried a regular bulb and still didn't work.
I checked the power at the socket with the switch on (checked the tab and socket shell) and was getting power to the socket, but no light
Old 11-30-2011, 05:42 PM   #7
Is it possible that the tab inside the bottom of the socket that is supposed to touch the bottom of the bulb isn't bent up enough to make contact?
Old 12-03-2011, 11:49 AM   #8
Jfrotten, I got it to work thanks for the help
I switched out the dimmer from a known working light to my pendant lamp. The pendant lamp worked. I tried the non-working dimmer to the light I switched the dimmer out from, and it worked as well. So I putt original dimmer back on the pendant lamp, and it worked too. Maybe a loose wire or something at the dimmer .. the contractor did that one =)
thank you again for the help
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 09:28 PM
light / lamp inside speedcook microwave will not turn off Sears/GE Model 363.63673201 mtk Appliances 0 10-26-2010 06:56 PM
Replacing old outdoor mercury vapor lamp post insides proofer Electrical 12 07-04-2009 04:31 PM
Two Circuits in one Box? GFI for lamp post? Burbman Electrical 4 05-13-2009 03:59 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 02:39 PM
