Pendant Lamp Electrical Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 02:33 PM   #1
Pendant Lamp Electrical problems
I am new to the forum and a fellow DIYer at home. I don't have much experience but changing bulbs, fixing toilets, turning off breakers etc I can manage pretty well. The recent problem I have at home is 2 Pendant lamps that a contractor installed after I remodeled my home. The lights are setup like this
Switch -> Pendant A -> Pendant B (Location Pendant A is closer to the switch)
After about a year or so, Pendant A started to turn off by itself while Pendant B is on. I thought it was the bulb so I switched the bulb. The same thing happens the bulb is brand new and after 5 minutes Pendant A turns off by itself (a slow dim) while Pendant B is on and have no problems. I called the contractor back and he said that the since they are on the same wiring if Pendant B is on and have no problems then its not the wiring its Pendant A's transformer.
So I went to home depot and got the a new pendant. I installed the new Pendant A, everything worked fine for about 2 weeks. The problem began again. Pendant A slowly dims and turns off, while Pendant B is on and have no problems.
Please let me know your thoughts and any ideas why this is happening.
JeffDIY is offline   Reply With Quote
Old 10-11-2012, 04:36 PM   #2
Oso954's Avatar
Rewards Points: 746
Even though "a" is closer to the switch, the wires might run to "b" first, particularly if this is a relocation from a light that existed prior to the remodel.
I would check the connections in location "b", just to be sure.
Oso954 is online now   Reply With Quote
Hvac electrical problems jrf4x4 HVAC 6 08-15-2012 12:16 AM
Electrical Problems in a Rental Home ztheday Electrical 16 06-07-2012 12:29 PM
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 08:35 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 01:16 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
