Old 03-07-2011, 03:11 AM   #1
Pendant Box Wiring
Can anyone explain why my shallow depth pendant light box is wired with 2 black, 2 white and 2 ground wires? I have 2 boxes wired this way and 1 box wired traditionally with 1 set of wires - 3 total over the island in the kitchen.
Does anyone know what type of light requires this type of wiring?
I'll try to post a pic too.
Thanks for your help.
Rob
Dragonballz is offline   Reply With Quote
Old 03-07-2011, 03:28 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
Pendant Box Wiring
one cable is power in the other power out to the next light or a switch leg
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-07-2011, 11:33 AM   #3
Pendant Box Wiring
Cowboy,
Thanks for the reply. That's what I was thinking too when I saw it but its interesting all the black and white wires are separated. I figured the original daisy chain would be tied together.
Rob
Old 03-08-2011, 12:52 AM   #4
Scared Electrician
Pendant Box Wiring
have you considered the switch leg scenario?
Old 03-08-2011, 01:29 PM   #5
Pendant Box Wiring
Can you explain a switch leg?
Thanks.
Old 03-08-2011, 09:30 PM   #6
Scared Electrician
Pendant Box Wiring
Lets say that the incoming power wire(cable) comes (directly or indirectly) from the breaker box to the light. Great now any time the breaker is on we have light but not exactly what we want:P so we need to run a wire(cable) to the switch box from the light box if we want it control the light using a switch. Now we will send incoming power down to the light(by code using the white wire marked with some black tape) and send the power thru the switch and back to the light box and back to the light. SO back at a light box wired in such a manor you would have two cables with 2 blacks 2 whites(one marked black) and two grounds. only two of these wires would be connected to the light fixture itself, the incoming white and the returning black. the other two are tied together(yes a white and a black under the same wire nut.
In order to tell if you light is wired using a switch leg scenario, the easy way is to open the switch box and to look and see how many cable enter the box(one if switch leg)
Wiring a new track pendant light fixture achettiar Electrical 1 03-29-2010 02:26 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 33 03-18-2009 08:11 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
