-   -   Pendant Box Wiring (http://www.diychatroom.com/f18/pendant-box-wiring-97508/)
Dragonballz 03-07-2011 02:11 AM
Pendant Box Wiring
Can anyone explain why my shallow depth pendant light box is wired with 2 black, 2 white and 2 ground wires? I have 2 boxes wired this way and 1 box wired traditionally with 1 set of wires - 3 total over the island in the kitchen.
Does anyone know what type of light requires this type of wiring?
I'll try to post a pic too.
Thanks for your help.
Rob
Saturday Cowboy 03-07-2011 02:28 AM
one cable is power in the other power out to the next light or a switch leg
Dragonballz 03-07-2011 10:33 AM
Cowboy,
Thanks for the reply. That's what I was thinking too when I saw it but its interesting all the black and white wires are separated. I figured the original daisy chain would be tied together.
Rob
Saturday Cowboy 03-07-2011 11:52 PM
have you considered the switch leg scenario?
Dragonballz 03-08-2011 12:29 PM
Can you explain a switch leg?
Thanks.
Saturday Cowboy 03-08-2011 08:30 PM
Lets say that the incoming power wire(cable) comes (directly or indirectly) from the breaker box to the light. Great now any time the breaker is on we have light:) but not exactly what we want:P so we need to run a wire(cable) to the switch box from the light box if we want it control the light using a switch. Now we will send incoming power down to the light(by code using the white wire marked with some black tape) and send the power thru the switch and back to the light box and back to the light. SO back at a light box wired in such a manor you would have two cables with 2 blacks 2 whites(one marked black) and two grounds. only two of these wires would be connected to the light fixture itself, the incoming white and the returning black. the other two are tied together(yes a white and a black under the same wire nut.
In order to tell if you light is wired using a switch leg scenario, the easy way is to open the switch box and to look and see how many cable enter the box(one if switch leg)
