Pellet Stove Auger Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 04:59 PM   #1
Hello, I would like to install into my pellet stove an aftermarket auger motor time delay switch that is allot less expensive then the replacement control board (with timer built in) from the dealer. Stove runs on 110v ac & the original timer operates like this:
On energizing with auger feed (delay switch) set on it's minimum the power goes to the auger motor and runs for 3 seconds then d-energizes power to the auger for 5 seconds and will keep repeating till the auger feed (delay switch) is turned up.
I am now retired disabled (Legally Blind) and really can't afford a OEM replacement control board (with delay timer built in) for this stove. I would appreciate any and all ideas for this repair as inexpensively as possible. Thanks in advance, Lance
Lance58 is offline   Reply With Quote
Pellet Stove Auger Motor Question shumakerscott Appliances 0 04-15-2012 02:30 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Tiling under a pellet stove exiledgator Tiling, ceramics, marble 5 06-14-2011 09:43 AM
Hooking up a non-equipped pellet stove to a home thermostat bobbyc HVAC 4 09-25-2009 03:24 PM
Finishing Basement with Pellet Stove BCav12861 Building & Construction 1 08-15-2008 10:16 PM
