Peerless 5 HP 3 Phase Motor Hums... - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2012, 02:49 PM   #1
Peerless 5 HP 3 phase motor hums...
Hi, I'm trying to get an old air compressor going again, but when power is applied, it just hums. I've checked power and 220 is on all 3 legs at the switch box. I can easily rotate the pump and motor by pulling on the belts so I don't think I have any bad bearings. I'm thinking the centrifugal switch is bad and wondering if someone can tell me if it is located on the end in the attached picture. If so, will removing the 4 screws around the round cap allow me access to it? I'm afraid if I take the cap off, I may end up with more problems... The specifics of the old motor are:
Peerless, 5 hp, 1750 rpm, 40 c(?), 3 phase, 200-440 volt, 60 hz, 13-6.5 amp, CON duty, Frame PH254, Serial 403257.
I'd greatly appreciate any help. Thank you in advance! Pat
Poodlehead is offline   Reply With Quote
Old 12-01-2012, 04:01 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Where is this pump located that you have 3 phase? This really isn't DIY... best call in an electrician.
Old 12-01-2012, 04:07 PM   #3
Rewards Points: 14,000
You do now your house is not going to have 3 phase power, right?
If you really do have 3 phase where your trying to get it to run are you sure the motors not wired to run with 440?
Open up the cover where the wires are and there should be a wiring diagram telling how to switch back to 220.
Old 12-01-2012, 04:18 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
3 phase motors do not have centrifugal switches. Will the motor start and run if you spin it in either direction by hand? If it does then you have a missing phase.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 3 Users Say Thank You to electures For This Useful Post:
NJMarine (12-08-2012), plummen (12-09-2012), Speedy Petey (12-02-2012)
Old 12-01-2012, 06:16 PM   #5
The pump is located in an old automotive restoration shop that my uncle had. It is an old DeVilbiss compressor that is probably 40-50 years old. I know my uncle took care of it through the years. I'm guessing it hasn't been running in 10 years or so now... Power is controlled by a heavy duty 3-pole on/off switch (similar to an AC lockout switch by an HVAC compressor).
I measured voltage between the 3 pairs and I get 230 and 247 readings between the pairs. Holding one lead on the left most incoming wire, I get 230 to the center wire, 247 to the right most wire. Moving my one lead to center wire, I get 230 to left wire and 247 on the right most wire. Moving my one lead to the right wire, I get 247 on the left most and center wire...
I've got a guy coming over tomorrow that is smarter than me and hopefully can figure it out... I'll let you all know what happens. Thanks!
The Following User Says Thank You to Poodlehead For This Useful Post:
stickboy1375 (12-01-2012)
Old 12-01-2012, 10:07 PM   #6
Idiot Emeritus
Rewards Points: 1,492
Your voltage readings certainly indicate 3 phase. If there are fuses between where you took the voltage readings and the motor, one of them is likely blown. Only one, not two or all 3.
Another possibility is the controller. There's a chance it is closing only two of the 3 phases to the motor. It could also be the motor itself, or the connections in its terminal box.
The voltage readings show a pretty serious imbalance. It's possible there's a failing (but not completely failed) component anywhere from the supply all the way to where the readings were taken. Take the voltage readings under load, but be careful; don't let the motor just hum without actually running for longer than a few seconds.
Rob
micromind is offline   Reply With Quote
The Following 2 Users Say Thank You to micromind For This Useful Post:
Poodlehead (12-02-2012), Speedy Petey (12-02-2012)
Old 12-02-2012, 02:36 AM   #7
Semi-Pro Electro-Geek
Measuring current draw on each of the phases will be much more informative. That will narrow it down a lot.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 12-02-2012, 06:32 AM   #8
Rewards Points: 38
had saw dust in a contactor once. amazing what some compressed air and installing the cover correctly will do in a wood shop. my bet is a blown fuse.
bernie
bernie963 is offline   Reply With Quote
Old 12-02-2012, 08:27 AM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Rob
Rob did a great job summarizing your issues. With three phase motors about 90% of the time it is single phasing if all it does is hum and barely rotates. Only thing I will add to Rob's reply is that what he is telling you is troubleshooting a motor problem involves isolating where the probelm is ... in the motor or in the supply and devices. It sounds like your starting the motor across the line or in other words just closing a switch from the supply to the motor terminals. You do not mention any starters with contact and overloads. So I'm visualizing protection for the wiring being a 3 pole breaker or fuses in a panel, 3 phase wiring to a 3 pole saftey knife blade type switch, then to the motor.
It looks like you have all three phases to the switch, though you have close to 5% change with one phase, that is somethong that is not quite correct as it is just outside what would be considerd an bad imbalance. I am assuming your taking the voltage readings line side of the switch terminals. Do not close that switch and then take voltage readings .. that is way too much time to let the motor hum and heat up. I do not like 3 phase motors that do not have motor starters with overloads controlling and protecting them.
Anyway your motor just hums and doesn't rotate. I'd disconnect at the motor terminal box and recheck voltages a L1 L2 and L3. If you get the same results your not single phasing from the supply, though an imbalance is apparent. Still though if your motor is good it should run. Next would be possible wiring error to the motor leads.
Has anyone reconnected the wirng to the motor?
Hopefuly if that is the case you haven't damaged your motor. If the name plate is still attached to the motor check the wiring diagram for proper connections. That being ok it is almost certain you have a bad winding(s) causing the motor to single phase. There are ways to check for a bad winding but if that is the case might as well get a new motor which really should not be that expensive.
If the motor has been reconnected and no wiring diagram exists then we might be able to show you how to check winding continuity to reach the correct connections based on the number of motor leads ..ie..9 or 12 leads etc.
The Following 2 Users Say Thank You to Stubbie For This Useful Post:
micromind (12-02-2012), Poodlehead (12-02-2012)
Old 12-02-2012, 08:28 AM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Rob
Duplicate post ...sorry ...problem with posting reply
Old 12-02-2012, 04:38 PM   #11
Progress...
Looks like we have identified the problem of one of the 3 poles (left most) not being connected at the meter. The meter was replaced a year or so ago with a digital meter. It looks like the proper meter (4W), but it is cocked where the bottom sticks out, so one pole is probably not connected...
The configuration is power from the meter through a box where fuses are in series for each of the 3 poles, then to the switch box where it connects to the 3 knife blade sockets on the non-movable contact side. The moveable contact side of the 3 pole switch has a fuse in series with each pole that goes through the pressure switch and to the motor.
Troubleshooting showed the middle and right knife blades significantly arcing when making/breaking the switch, but not the left most pole. Measuring voltages with an analog meter showed the left most leg dropping out when the load was applied. This was all the way back to before the first fuse coming in from the supply/meter. The 230 vac on the left pole that I was measuring before must have been a floating voltage. I wanted to re-measure from the right most pole to the other 2 poles, because both of the previous readings showed 247, but when I tried to measure, I had a problem with my meter...
Anyway, I'll follow-up after the city comes out and checks their meter...
Thank you all for the great feedback. This was my first problem post to this DIY group and you all have been great! I hope I can give back what you all have given me.
Thanks,
Pat
Old 12-02-2012, 04:47 PM   #12
Progress...
Thanks,
Pat
Old 12-03-2012, 11:16 AM   #13
Problem solved!
Well the problem wasn't at the meter, but up at the transformer. There was a blown fuse at the transformer. After replacing the fuse, the compressor ran like a "top".
One thing I learned from this is that I intend on rigging up a light bulb socket with test leads. If I had checked each phase to gnd with a 150W light bulb, I probably would have gotten the answer a lot sooner...
Anyway, thank you all for your help!
Pat
Old 12-03-2012, 02:25 PM   #14
Pat
If you had check each phase to ground with a light bulb, you would get a burned out light bulb! One of those phases is 208V to ground.
Old 12-03-2012, 03:11 PM   #15
I thought all 3 phases were the same, about 110-125, with respect to ground. I was measuring 230-247 between phases, which is double a one phase measurement. I guess I'm a bit 'corn-fused'...
hELP! Amperage needed for 220V motors 1488rob Electrical 36 01-28-2014 04:44 PM
Three phase transformer question rongaudier Electrical 8 03-08-2011 07:19 AM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 09:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
