Pedestal To House 80 Feet AWG Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 01:47 PM   #1
Rewards Points: 248
Pedestal to House 80 feet AWG question
An engineer who works for a company that sold me a meter pedestal looked up the required wire thickness to go from a meter pedestal near the road to the house. About 80 feet distance. The house plans call for max 100AMP. I do not envision using more than 60AMPS. He said 2 AWG is too small. He claims that according to the local codes the max they'll let you go with 2 AWG is 30 feet. I will need 1 AWG. Does that sound right? The guy at Home Depot said that 2 AWG is rated for 95 AMPS up to 100 feet. Do the codes differ so much from ratings?
jackwashere is offline   Reply With Quote
Old 03-28-2012, 01:51 PM   #2
Licensed electrician
Rewards Points: 1,038
We have no way of know your local codes since we don't even know where you are.
The NEC would allow #2 aluminum or #4 copper for the dwelling.
light receptacle vs. switch test device amakarevic Electrical 5 03-23-2012 06:15 PM
Radon test with 5pCi/L adgjqetuo HVAC 6 02-18-2012 08:52 PM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 11:44 PM
